Old 08-09-2018, 04:12 PM
lr172 lr172 is offline
Default Flying to Denver: turbulence concerns
I plan to fly into Denver this weekend and this will be my first time flying in the rockies. I understand the basics of the rotors that develop when the wind crosses the ridges at 90* and I understand the basics of flying over mountains (have crossed the Appalachians several times). However, to land in Denver I need to descend through the rotor zone.
I frankly don't know who to ask for guidance on dealing with this and was hoping that some Denver area folks can help me with some general guidelines. I am going into AHA and will go IFR. I was hoping that ATC would provide some guidance or Pireps but not sure.
I would appreciate any guidance or suggestions from local pilots.
Larry
Old 08-09-2018, 04:21 PM
JimWoo50 JimWoo50 is offline
Default 11am to 4pm
been my experience the above hours are most likely to be rough especially on a bright sunny day below the cumulus. Have fun.
Jim Woolard C56
N9855J RV-6 Donated 2020
Old 08-09-2018, 04:36 PM
hacker hacker is online now
Hi Larry,
First I'm assuming your coming from the East by your address. If so you should have no issues related to "rotor zone" this time of year. Strong turbulence issues usually don't begin till October or such as the upper level winds are usually quite benign in the summer. Dodging thunderstorms or high density altitude issues should be your only concerns. You can expect some mid afternoon turbulence if you arrive after 12 but just more of a discomfort than any thing else.
I have been flying out in the Denver area for over 30 years, all types of aircraft, and wouldn't hesitate to recommend flying here this time of year in GA aircraft. In addition flying in and around the mountains is one the great joys to be found out here. Just check the winds at 12K and if they aren't out of the west at over 25 knots your good to go. Keep an eye out for gusty surface winds and possible LLWS at some airports along the way but usually not a problem. Might add I have been giving Mountain flying seminars to pilots for many years out here. You question is a great one to ask!
BTW, not familiar with AHA, perhaps your referring to KAPA. If so easy peasy trip
Have a great flight!....DR
Old 08-09-2018, 05:27 PM
Originally Posted by hacker View Post
Hi Larry,
BTW, not familiar with AHA, perhaps your referring to KAPA. If so easy peasy trip.
Thanks so much for the insight; It is much appreciated. Yes, we are going into Centennial (APA), I was typing too quickly. Plenty of T storms to dodge here in Illinois, as well as convective turbulence this time of year, so used to that. Saturday is looking like a great day to fly for the whole West.
Larry
Old 08-09-2018, 05:33 PM
I haven't flown over the mountains back east, but have flown over the Rockies. I would bet it isn't the same or even close. If you are coming from the east, you will not have any mountain flying so no worry. Find a local guy and go for a mountain flight. It will be worth the time and you will enjoy it. If you are prepared, nothing to fear and the views are amazing.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 08-09-2018, 06:11 PM
Ditto what Hacker said.
Dave
Old 08-09-2018, 08:00 PM
MConner MConner is offline
Take off at dawn and land before noon for the best ride. Rotor and wave are not present with upper level winds below 40 knots, mostly winter issues.
Mark
Mark
RV-10
Bought not built
EAA 180
48X
Old 08-09-2018, 08:06 PM
airguy's Avatar
airguy airguy is offline
There's a good restaurant at the upper level of the FBO - been there a few times. Good luck on the trip!
Old 08-09-2018, 08:12 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I attended the Colorado Pilots Association forums at Oshkosh the last 2 years. Very good sessions.
Great info on rotors and mountain waves.
Their website has lots of great info and tools to make flying safer in the rockies.
http://coloradopilots.org
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 08-10-2018, 06:36 AM
Red Mtn flyer Red Mtn flyer is offline
Ditto Hacker. From the East, your greatest challenge is avoiding traffic and the Class B. Both APA and FTG are busy training spots; both have restaurants for food flights. APA, your closest approach, is 20 miles from the foothills; wave formation is unlikely until October.
Flying those mountains is demanding: your rate of climb [often the critical factor] decreases about 7% per thousand feet of altitude. Translate that: at 10,000', your climb rate is decreased SEVENTY PERCENT. A 10 degree increase above ISO temperature will increase your ground roll by 10% -- as will every 1000' of ASL.
The orographic challenges are not comparable between the Rockies and the Appalachians - each has its own mysteries and difficulties. I spent way too much time looking for scattered aluminum around the high passes of Colorado -- please get some familiarization help if you go West from Denver [or just go to 16,000 and stay there].... but getting into Denver is not that problem.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
