08-02-2018, 05:31 PM
Air Conditioning
Just spoke w/ Bill at Airflow Systems ( https://www.airflow-systems.com/rv-10/). Very helpful! Really wish they had more photos on website, although I did learn a lot from those posting here on VAF. Figured some others may have similar questions, so... - Quickbuild presents no problems. AFAIK, baggage floor is not installed by Van's. If it is, then an access needs to be added for condenser lines.
- Routing lines down pax sidewall is a good way to go, since it is cooler and does not further clutter the tunnel. Builder routes the lines then obtains a loaner crimping tool from Airflow to install fittings.
- Airflow offers a so-called "Australian" option for increased evaporator airflow, but I don't think I need it. Adds about 5 lbs and 5 Amps draw.
- Evaporator airflow can be improved by using flat vents in place of eyeball vents in overhead. I'm planning to use the carbon fiber Aerosport Products Overhead Console (http://www.aerosportproducts.com/rv10overhead.htm), but may stick w/ the cool looking (costly!) eyeball vents.
- Installed system weighs about 40 lbs
- I will forego a fresh air mixing valve in favor of keeping stock front and rear fresh air vents. Not as elegant, but really simple.
- Panel switches include an ON-OFF and a separate 3 position fan speed control.
- From what I can tell, early problems with belts and idler pulley have been solved w/ serpentine belt system.
- Recommends turn-down exhaust extensions to both direct hot exhaust away from condenser, and help quieten airplane.
- Recommends sending flywheel to engine builder (in my case, Barrett) and tell them to make sure the pad on the lower LHS of block is drilled and tapped w/ studs for the compressor/idler mount.
- Recommends increasing oil cooler from stock 13-row to 15-row, which needs turning vanes at inlet to improve air flow. Also, install manually operated butterfly in duct to oil cooler to regulate as needed.
- Recommends adding cowl louvers on lower side(s) for improved exit air flow that can later be blocked if it's more than what is needed for engine/oil cooling. Bottom of cowl is not a good place due to higher pressure at that location.
- Recommends sealing corrugated panels in aft baggage bulkheads.
- Evaporator sits on shelf and is accessed by removing upper aft baggage bulkhead for freon charging, etc. Return air is appx 6" square penetration in lower aft baggage bulkhead.
- Expect installed system to shift CG about 1/2" aft.
FWIW, I've just about settled on sticking w/ standard updraft, fuel-injected, using 9:1 compression for about 275hp. I really prefer cold air induction, but will likely choose to not deal w/ all the cowl, exhaust, and other work needed to make that work. If it were up to me I wouldn't install air conditioning, but it's not up to me.
Kliff
Granbury Texas
RV-7 QB (N74KB) - Flying
RV-10 QB - Empennage Started
08-02-2018, 05:47 PM
I had my RV-10 transition training with Alex in TX during September. His 10 had AC and you will be glad you installed it 🔥🔥
David C.
Howell, MI
08-02-2018, 07:40 PM
Air conditioning
I have Airflow-Systems air conditioning in my RV10 since 2010 when I built it. I can't imagine flying the -10 in Oklahoma's hot summers without it. It has been working perfectly. Bill is an easy person to talk to and sells a great product. If you have any questions from a satisfied customer, give me a call. I occasionally go to flyins in the Grandbury area and would be glad to give you a ride to see the difference. I'm located in Tulsa at KRVS.
08-03-2018, 08:17 AM
Interesting, I've got most of my airflow systems A/C plumbed firewall back and he never mentioned anything about.
1. Needing exhaust extensions.
2. Needing a return air in the rear bulkhead.
3. Needing to increase the size of the oil cooler.
Not sure on your engine, but he sent me a machined flywheel to replace my stock one.
You're welcome to come check out my install, I'm just south of Dallas in Cedar Hill.
Lynn
RV-10 in Process
08-03-2018, 10:33 AM
I have Bill’s system on my 10. Just clipped 500 hours.
Loved it on the most recent OSH trip. No matter what anyone says about not being needed once you’re in the air, that cabin can really heat up in the sun. If you’re facing the sun, the windscreen is like a magnifying glass and you’re the ant even if the OAT is mild. If you have it, you’ll use it way more than you anticipated.
I have the larger 07 oil cooler and did have to add a butterfly just to keep it in the green in winter.
I have the shark gills on the side.
I operated the system for about the first year using tailcone air. I then fabbed a cabin air inlet. Minor improvement, especially in taxi.
I have the exhaust tip extenders. They come with a single bolt each but the bolts aren’t necessary. Just slip them on, they won’t come off. I don’t use them all the time, just short hops in hot weather. They do make a difference, especially in descent when warm air does seem to enter the scoop.
Never heard of the Australian option.
If building again I would absolutely, without hesitation, install A/C again.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
08-03-2018, 02:05 PM
Comparison...
How does this compare with Flightline's AC systems?
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/N1FLY
08-03-2018, 03:20 PM
Originally Posted by kblack
...[*]Installed system weighs about 40 lbs
Interesting. I read a very thorough pirep from an engineer who installed an AirFlow Systems unit on his Glasair II and his W&B table shows weight increased 60 lbs... did you happen to actually measure your installed weight? Or did Bill significantly lighten his system recently?
08-03-2018, 03:37 PM
Are you installing a/c in the 9?
Nigel
RV9A-N113SQ
52F
08-06-2018, 01:14 PM
Follow Up
Several items like Exhaust Extensions, Return Air Grill Location, ..., came up because I specifically asked. Weight is what I was told. My bet is that does not include things like an overhead console to distribute the air. It may also omit hoses which vary due to builder routing preferences.
I'll definitely plan to follow up w/ some of you guys to see your installations as I get a bit further along. Thanks for the offers!
Kliff
Granbury Texas
08-07-2018, 08:07 AM
Edit: I finally found the log entry and total weight for the components from Bill came in at 43 lbs. This was for all the normal components, compressor, brackets, hoses, scoop, condenser, shelf, New Flywheel, etc. Everything he sent. So now you have to add to that the weight for refrigerant and the overhead console, and any other misc.
One thing I will say is Bill has been great at sending different fittings as I modified the install for my plane. The install has added a lot of time to my build, but it's the one thing I've wanted from the beginning.
Lynn
RV-10 in Process
Reason: weight
