Old 08-04-2018, 02:21 PM
rsr3 rsr3 is offline
Default Just about to order my wings
Hi folks,
Just about to order my wings for RV7. I?ve read things such as upgraded fuel caps are worthwhile, are there any suggestions you would make before I place the order?
Rob
Old 08-04-2018, 05:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Longerons
Yes, deluxe cap kit is nice. Conduit is good but some have other opinions.
Buy the Cleveland tie down kit. The anchor plates are tapped. Mount them so the plate is flush to the skin.
Since Van's ships the fuse longerons with the wing spars, add an extra one or two longerons. Cheap to buy, expensive the ship of you make a mistake.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-04-2018, 10:27 PM
jcarne's Avatar
jcarne jcarne is offline
Here are the extras I added to mine. DEFINITELY get extra longerons just in case. I didn't end up needing them but man that shipping would have sucked!!!
Delete standard fuel caps 2.00
Extra Longerons F-718 2.00
Deluxe Locking Fuel Cap FUEL CAP DELUX W/LOCK 2.00
Pre-built Fuel Pickup F FUEL TANK PU W/SCRN 1.00
Flop Tube IF-4/6 1.00
Nylon Conduit DUCT NT5/8-50 1.00
Bellcrank Jig W-730 1.00
Tank Test kit FUEL TANK TEST KIT 1.00
Angle .125 3/4 x 3/4 6ft AA6-125X3/4X3/4X6' 1.00
Angle .125 1 x 1 6ft. AA6-125X1X1X6' 1.00
Angle .063 3/4 x 3/4 6ft. AA6-063X3/4X3/4X6' 1.00
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 08-04-2018, 10:36 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I got the non-locking deluxe fuel caps.
Some large flange hinge pieces if you want to do the hidden hinge wing tip attachment method.
The other suggestions are good.
Mike W
Venice, FL
N164WM
Old 08-07-2018, 01:01 AM
Thank you for the replies!
Old 08-07-2018, 08:16 AM
NavyS3BNFO NavyS3BNFO is offline
I wish I knew about the Cleaveland tie down kit. Tapping the aluminum wasn't fun plus those tie down rings look really nice. I would have definitely splurged for those. A good value.
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
