Old 08-02-2018, 08:31 AM
jibby212 jibby212 is offline
Default Throttle quadrant in center console RV7
I did some of my flight training in a Piper Sport Cruiser which is my favorite plane that I have flown to date, never been in an RV yet. I like the center console mount Throttle quadrant and I am planning on doing some right seat flying. I was always planning on putting a quadrant in my RV7 but the added time and narrow cabin have me thinking otherwise. I have just received my finishing kit so the time is fast aproaching to make a decision. I am looking for a narrow 2 lever (fixed pitch) console mount quadrant. I see the side mount models available for the RV8, maybe it could be easily modified to mount in a flush console. I also tossed around the idea of a single lever quadrant and the mixture in the standard location but that might not be so good when full rich and full throttle are needed. My main question here is if anybody knows of a good, very narrow quadrant that is good for left or right hand operaton that can be mounted in a flush center console.
Old 08-02-2018, 08:45 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try contacting Dayton Murdock. He is the manufacturer of the quadrants.
http://www.vansairforce.com/community/member.php?u=395
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-02-2018, 09:49 AM
Walt's Avatar
Walt Walt is offline
You'll likely regret installing that quadrant the first time you have to crawl under the panel
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-02-2018, 10:03 AM
Doug Rohrer Doug Rohrer is offline
Default Center Quadrant
I have a two-lever quadrant that was in an RV-9A. It is the Van's CT82F Deluxe quadrant with a fabricated bracket for center mounting. It includes cables for an O-320 E2D engine plus all mounting hardware. You can have it all for $150.00 plus shipping. PM for pics.
Doug Rohrer
Bowling Green, KY
Old 08-02-2018, 11:53 AM
Bevan Bevan is offline
Or the panel can be made modular so most wiring and servicing can be done when sitting upright in the seats. Bevan.
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-02-2018, 12:00 PM
Dan92 Dan92 is offline
I have a center mounted quadrant in my RV-7A. It's an RV-10 three lever quadrant and I love it even though I did have to crawl under the panel a couple of times.
Dan
Old 08-02-2018, 02:12 PM
tomww tomww is offline
I've got an Andair 3 lever quadrant. Wouldn't dream of changing it. And I've just redone the panel. No problem at all. I just took out the passenger stick.
Old 08-02-2018, 04:44 PM
N941WR's Avatar
N941WR N941WR is offline
Put one in my -9. One of the best mods I did.
Check out my website for details or use the search function, lots of pictures will come up.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-02-2018, 08:27 PM
Maverick972 Maverick972 is offline
Thanks for starting this thread as I am seriously considering putting a throttle quadrant in my 7.
Sean P. McGrath
RV7 730JK
2020 Dues Paid.
