07-29-2018, 07:03 AM
Flying with or without wing tie down rings
A quick question to all flying RV-12 drivers. Do you fly with the wing tie down rings attached, or do you always remove them before flying?
What is best practice here?
Thanks a lot
Chris
07-29-2018, 07:32 AM
I remove them. Probably not much chance that they would work loose and fall out but why risk it? Less drag too, although it wouldn't be noticeable. Should add that I don't often use them as my plane is nearly always hangared.
rgmwa
RV-12LR 912ULS
120346
07-29-2018, 07:52 AM
I only tie down on rare occasions, so I install when needed and normally have them in the glove box. So far, in fact, I think I've only used them at Oshkosh. The rest of the time I just chock the nose wheel. I'm generally never parked outside fo the hangar for more than a few hours.
Dale
Omaha, NE
Previous RV-7 project (sold)
07-29-2018, 08:19 AM
I'm one of the unlucky hangerless owners in SoFla. and tie down. I never remove for flight and do not see airspeed reduction or risk of loss in flight.
Steve at LNA now after BCT tripled rent!
Flying a built ELSA
07-29-2018, 08:24 AM
Once I forgot to remove them and accidentally flew several hundred miles in my Lancair with them hanging down in the breeze. I didn't notice any difference in performance, but did add "Check tiedown rings removed" to my preflight checklist.
(2020 dues paid)
07-29-2018, 02:13 PM
I only remove mine at annual when I install hex head bolts as jack points to jack up one wing at a time for wheel and brake maintenance. I bought a tall hydraulic jack from Nortern Hydraulics and machined a cup on one end of a 2? OD AL bar for the jacking bolt hex head. I bored the other end of the bar to slip over the end of the hydraulic jack shaft. The AL bar is about 4? long. Works great.
07-29-2018, 04:42 PM
Remove the steel rings from the aluminum fittings.
That would be a hint.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
07-30-2018, 08:15 AM
tie down rings
Good Hint! Yes electralisis still exists!
07-30-2018, 10:06 AM
Would that include all bolts in the airplane?😜
07-30-2018, 10:16 AM
And...
Yep, better remove any dissimilar junctions throughout the airplane!
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
