Old 07-03-2018, 07:25 AM
Carl Froehlich's Avatar
Default RV-8 three view drawings
Anyone have 3 view PDF drawings for the RV-8? I can?t get the weird Van?s drawing download to work.
Carl
Old 07-03-2018, 07:48 AM
terrye terrye is offline
You mean the download itself doesn't work, or you can't open them once you've downloaded?
First, the download is a zip file so, you need WinZip or similar to unzip them in your computer. Second, the 3 view files are in .DWG/DXF format so you must have AutoCAD or similar to open them. There are links on the Van's download site for free WinZip/AutoCAD programs.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 07-03-2018, 07:56 AM
Yep - tried all that. Unzip is not the problem, the stupid DWG/DXF format is kicking me.
Still looking for simple PDF files.
Carl
Old 07-03-2018, 08:12 AM
Check your email.
Terry Edwards
RV-9A (Fuselage)
Old 07-04-2018, 09:43 AM
goatflieg's Avatar
goatflieg goatflieg is offline
If Terry didn't already cover it, let me know. I digitized them for designing my artwork.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 07-07-2018, 06:52 PM
Sam_B Sam_B is offline
Default Draft Sight
You could also get a software called Draft Sight, it?s a free download from Dassault Systems, the same people that make Solidworks. It?s pretty much a copy of AutoCAD (all commands are the same in every way if you are familiar with that software). Then you can manipulate the drawings if you?d like.
Old 07-25-2018, 08:00 AM
Roo747's Avatar
Roo747 Roo747 is offline
Default avidyne drawings
speaking of the 8 3D files, does anyone know where you can get a file for the avidyne IFD540?
Andrew
Old 07-25-2018, 02:45 PM
Lufthans's Avatar
Lufthans Lufthans is offline
Originally Posted by Sam_B View Post
You could also get a software called Draft Sight, it’s a free download from Dassault Systems, the same people that make Solidworks. It’s pretty much a copy of AutoCAD (all commands are the same in every way if you are familiar with that software). Then you can manipulate the drawings if you’d like.
Or, if you are an EAA member, you can get the full Solidworks license through EAA. Quite a steep learning curve though.
Dassault also has a free program called eDrawings, which is a CAD viewer. I believe it also handles the Autocad files. Good thing about eDrawings is that it also runs on Mac (or even mobile phones). http://www.edrawingsviewer.com
Hans Teijgeler
Hilversum, The Netherlands
Resurrecting an RV-3B
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
