Old 07-14-2018, 07:23 PM
bayoubengal bayoubengal is offline
Default Questions on KitLogPro
Have a couple of regarding KitLogPro. I bought a new computer and am trying to get operational on a second computer. No response yet from support. FAQ has cursory instructions I found of no help. Help function takes you to Microsoft help. Useless.
Also, having trouble figuring how to upload pictures.
Any help would be greatly appreciated.
VR
Hutch
Hutch
David W. Hutchinson
NAAA/PAAO Certified Aircraft Appraiser (Nationwide)
Perry, GA.
RV-10/N433DH (Res)
www.TwoEaglesAviation.com
Old 07-14-2018, 08:08 PM
Default Kitlog
Hey,
If you go to kitlog.com, there is a help column on the right side. Look for the installing kitlog on windows 10 link. Download the program and follow the instructions carefully.
If you already have a kitlog.mdb file, follow the instructions for copying the file into the specified directory.
You then can restart kitlog and your original log will be available.
To upload photos, plug your camera into the computer and import your photos. If you are using windows 10, they should end up in the pictures/photos folder.
In kitlog, make a construction log entry. Select picture 1. A window will open. Navigate to you pictures/photos folder. Select one picture. It will appear in you kitlog entry. Select picture 2, repeat process. You can have 3 pictures per log entry.
Hope this helps!
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 07-15-2018, 12:53 PM
DRMA DRMA is offline
Suggest you try the install instructions in posting #5 of the thread at http://www.vansairforce.com/communit...ghlight=Kitlog
The search function in VAF will usually find previous postings that can answer questions with just a few minutes of searching and reading.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 07-16-2018, 11:12 PM
Thanks guys. Will try again when I get back home...
Hutch
David W. Hutchinson
Perry, GA.
RV-10/N433DH (Res)
Old 07-17-2018, 06:30 AM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Kitlog-Windows10
I just moved my kitlog from an old computer to a new computer with Windows 10. Following is a link for info which I used--worked without any issues.
www.kitlog.com/Windows10/
Steve
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-20
www.mykitlog.com/skyking90200
Old 07-17-2018, 07:53 AM
219PB 219PB is offline
I am still having issues making a pdf copy for my archives.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 07-17-2018, 08:46 AM
Default Issue
You said you are having ussues with creating a pdf report?
Are you using that most recent version?
If so, do you by chance have an epson printer installed?
I had an issue trying to generate reports and after many weeks of trying to figure it out, determined that the epson printer driver is incompatible with kitlog pro. It is repeatable and verifiable. I had to uninstall the printer driver (and printer) to make kitlog pro work correctly...
Bob
RV-10
297 HP Barrett Hung
Wiring...
