Old 06-30-2018, 12:32 AM
mcoyne34 mcoyne34 is offline
Default 8 vs. 8A
I?m sure it?s been asked thousand times already, is there a noticeable difference between the two? Is it true that the 8A has a weak nose gear, and something I should be concerned about?
I was leaning towards the -8 until I got insurance quotes. At $1200/yr more for the tailwheel, it got me thinking about the 8A.
Old 06-30-2018, 03:32 AM
N661DJ N661DJ is offline
Question Insurance
Get some other quotes, an additional $1200. because of the tail wheel sounds excessive. My tailwheel 8 policy is slightly higher than what I paid for coverage on a previously owned 8A, everything else being equal.
Dick
Old 06-30-2018, 05:01 AM
RV6_flyer's Avatar
All the A model RVs have a front TAXI wheel that I would not call a nose gear. Fly the airplane correctly where the front wheel is only used as a taxi wheel and there is no problem.
Dick
My tailwheel RV policy is less than $300 for $1-Million liability only policy. Not sure my over 3,000 hours in tailwheel aircraft has to do with that.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-30-2018, 07:44 AM
tracy tracy is offline
$80,000 hull full coverage for my 8 tailwheel is $1000/yr. if you ever plan on grass strips, go with 8.
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 06-30-2018, 07:47 AM
rv8guy's Avatar
rv8guy rv8guy is offline
Is it time related. Mine went way down once I reached 500 hours tailwheel time. That was a while back
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 06-30-2018, 08:20 AM
acam37's Avatar
acam37 acam37 is offline
Low time tailwheel, expect around $1,800 year. That is what I paid on my 8 and 4 through Falcon.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 06-30-2018, 08:47 AM
dwranda dwranda is online now
Nobody ever told Vlad that I guess
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 06-30-2018, 09:07 AM
Low time, around 170TT IR pilot with zero tail time. All quotes wereassuming $80k hull. For tail dragger AVEMCO was $5900/yr, another insurance was $3600/yr and AOPA was $2600/yr. the -8A through AOPA was $1400/yr. So, it?s definitely time related and high due to lack of tailwheel.
Old 06-30-2018, 09:31 AM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Try talking to Gallagher or Falcon agencies. They are both popular in the experimental community and could find you a better quote.
An initial high quote may come down a lot after the first year once you've gained some time on type.
Old 06-30-2018, 10:24 AM
Gallagher was the $3600 quote. Couldn?t think of their name. I?m still a bit out, but I?ll see what Falcon says. Thanks
