Go Back   VAF Forums > Main > My RV Build Project
  #21
Old 04-15-2018, 11:10 PM
Tdeman's Avatar
Tdeman Tdeman is offline
Default Top Skin and Canopy Decks
In order to finalize the position of the ribs and sub panel, I made a bunch of small angles that spanned the notches/had the cutouts required for the sub panel and stiffener.
With the assembly somewhat rigid, I felt comfortable working on the top skin...
The outside curves of the sub panel, and the longeron to top skin holes were the only ones that needed to be back drilled.
With the skin ready for trimming/deburring/dimpling, I set it aside to work on initial fitting of the canopy decks.
When it was finally time to clean up this evening, the canopy decks were both ready for final deburring/notch cleaning, and countersinking.
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Opinions expressed in this post do not necessarily represent those of my employer.
Old 06-27-2018, 11:19 PM
Tdeman's Avatar
Default Drilling, drilling, drilling
RV-6 Update:
I?ve been taking advantage of the (rare) Oregon sunshine the past several weeks surfing and biking, but managing to get some RV-6 construction done in the evenings after work.
Did a bit with the baggage floor and forward seat pans...
Cut out some bulkhead stiffeners, and got the top J stringers temporarily riveted in place...
Began to fit rear aft top skin...
I ran out of edge distance with a few rivets near the forward end, so decided to remake the aft skin from an extra sheet of 2024.
Initially slightly bigger than the first one, the holes transferred in just a couple minutes.
The front aft-skin was much quicker and had better drill access.
Of course then I had to throw the forward top skin on, the seats in, and the baggage floor in to make it look like I?d made some real progress.
Plenty of drilling/hole layout to go, but such is the life of pre-pre-punched RV construction. I?m looking forward to fabricating less parts, and riveting more assemblies in the future!
Old 06-28-2018, 01:40 AM
RV7ForMe RV7ForMe is offline
Originally Posted by Tdeman View Post
RV-6 Update:
Being a -7 builder I cannot even begin to imagine the amount of work it must be to get this thing drilled straight. That said I enjoy seeing your Fuse come together. Looking like an airplane already..
VAF dues paid for 2021
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 06-28-2018, 11:53 AM
jcarne's Avatar
jcarne jcarne is offline
I do however envy never having to worry about holes not lining up.
By the way your work looks really good!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 06-29-2018, 02:07 PM
greghughespdx's Avatar
Lookin good, t-man. You get yourself wedged into in those seat frames and make airplane sounds yet?
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 07-25-2018, 12:57 PM
kentlik's Avatar
kentlik kentlik is offline
Hey! How is the project coming along? Are you about to hang the engine? Just kidding, I get that a lot...
Looking very good.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 09-16-2018, 03:29 PM
Tdeman's Avatar
Default Back to Building
It's getting too cold to surf, friends are heading back to university, and the mountain bike trails are still beat out from the summer of riding. That means it's time to get back on the build after several months of enjoying life outside the hangar.
First few items to take care of were small things I had been putting off a while, and a great chance to try out some of the new machine tools in the hangar.
My old (1994, non powder-coated) flap handle had some pretty deep corrosion pits on one of the arms. So I ground down the effected areas, and welded on a small patch of tube.
IMG_9197
Primed it, and then machined the slot for the manual flap-positioning mechanism, and also shortened the handle a few inches.
IMG_9227
I had already fit the flap bearing blocks on the outboard ends, but the middle bearing block sits part on the baggage floor, and part on the seat pan/tunnel. Rather than shim it with washers and have nutplates/fasteners out of plane with the surfaces, I machined a small set of wedges which got riveted to the tunnel cover, and to the seat rib, allowing the nutplates, bearing block, and bolt to all sit flat/vertical.
IMG_9230
I don't have a great vise for the mill, so starting with angle makes for easy work holding on small parts.
IMG_9237
(Ignore the too short, unset rivet in the above photo. It was used for aligning purposes only)
This should keep the fasteners happy.
IMG_9239
I wasn't happy with the previously made angle for the attach of the horizontal stab. Edge distance under the longerons was getting small, and these holes had to be further upsized for the AN-3 bolts.
The mill was already dirty, so I figured I might as well knock out a new one which could maintain every (thousandth) of an inch possible under there.
IMG_9215
IMG_9214
The original aft baggage side-panels did not fit real well (flanges would not sit flush with all mating surfaces), so I bent a new set on the brake which fit much better.
IMG_8904
Next is finalizing the custom seat pans (accommodating the 1" lowered seat ribs), and then some interior items might be going on permanently!
It's been a lot of making parts thus far, but one of these days the rivet gun is going to come out for more than a few whacks
IMG_9240
Canopy frame and baggage bulkhead coming soon.
Old 09-16-2018, 03:37 PM
Tdeman's Avatar
Thanks! A lot of it just comes down to work holding and throwing on more clamps than you think you need.
Thanks Jereme, seeing your surge of progress was more than motivational to get out there again.
Sure have! The more parts that get put in, the louder the noises seem to get.
Looking very good.
Kent, your progress is also looking good, and an appreciated reminder to keep moving forward
Old 12-15-2018, 11:54 PM
Tdeman's Avatar
Default Cold Progress
It?s been cold out in the hangar, but I?ve tried to keep the progress moving. I built a visqueen box to try and keep some heat in, and some moisture out, hence the change of backdrop! One benefit is it reflects much more light from the sides.
Finally tackled the seat pans. Things not quite being perfectly straight 90 degrees to each other in this area made it difficult to bend single sheets to fit everything for the lowered seat ribs? So a 3-piece seat pan was built because it was easy to make it register well on all surfaces.
IMG_9318
IMG_9351
Got the holes cut out in the forward seat pan as well for the control sticks. Also took a deep breath and did my spar carry through cutouts in the F-604. They came out real nice, with no gashes to the carry through.
IMG_9374
Of course with interior pieces finally coming together I had to throw them in to see how things were looking. Some fit and finish work is still required for a few interior panels, but overall most of the interior aluminum parts have been bent/shaped/drilled/fit.
IMG_9359
IMG_9512
Finally finish trimmed and zipped on the rear deck and aft tailcone skin.
IMG_9613
IMG_9638
And Lately I?ve moved on to some canopy fitting. Got the roll bar all fit, and slider tracks initially positioned. Traced canopy frame onto forward tailcone skin and made an initial skin trim just to allow it to sit in place.
Canopy frame tweaking will be next!
IMG_9679
IMG_9679
Old 02-04-2019, 12:30 AM
Tdeman's Avatar
Default Keeping it going
I got a deal on a second hand engine mount, gear legs, and wheels that came off of a colleagues RV-6. As a bonus, it had wheel and leg fairings already installed. I decided to see how the mount lined up with the holes that were in my firewall already. The top two holes were dead on, but the bottom two were both more then half a hole off to the inside… Symmetrically, so there was no way to realign the mount to get it to work… Measured the mount, and it’s right to spec, so somehow, sometime before I got it, the firewall and weldements were miss drilled to 1/4”. Time for some surgery to get things right…
IMG_9895
Unfortunately hidden rivets meant the side skins on both sides had to get peeled back a ways.
IMG_9906
One side done, one side to go.
IMG_9909
With both sides out, I welded the holes shut in the weldements, and match-drilled/remade the underlying aluminum gussets.
I ground the front flush to minimize drill bit walking, and reprimed them. This saved me from having to realign and drill a new set of weldements (and the price of the weldements).
IMG_9911
Reinstalled the gussets/brackets, and match drilled the engine mount (with the top of the engine mount bolted in place). It came out real nice, with only a snowman in the stainless firewall. The other side is identical. Not a structural concern.
IMG_9963
With the mount holes drilled, I figured I better make sure everything would go together…
IMG_9962
Needless to say, this one called for some airplane noise
Pulled the plane outside for its first time since I acquired it, and spent the rest of the day cleaning/organizing the hangar. Then back inside for a tear down so I can strip the paint off the engine mount and weld on the SB gussets. It was nice having this thing look (more) like an airplane for the day.
By the way, for cutting the gear leg clearance notch in the firewall, here’s a trick that was real easy, and gave me a near perfect line to reference (allowing for uniform clearance around the leg).
Cut a strip of aluminum about 12” long, and 1.375” wide (same as the gear socket ID.) Then cut a big notch in the side of one end, allowing it to reach around the firewall flange. A nice point on the end lets you turn the piece in the socket, maintaining contact with the outside surface, allowing you to see/mark right were the minimum cut would be made. I set a few strips of masking tape tangent to the point at various positions, then removed the mount, and cut back to just past the tape. Perfect cut the first time around
IMG_9956
