06-25-2018, 01:43 PM
Recommendations for a value paint job
Hi,
I have an RV-4 that needs new paint. I don't have a big check book, so I'm looking for recommendations for a strip and paint. I was hoping to stay in the $5-$7k range, but I'm not sure how much luck I'll have with that. I'm in the Midwest region, so closer is better.. (Can I get fries with that??)
Thanks for any info..
06-25-2018, 01:45 PM
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
06-25-2018, 02:07 PM
I looked for a long time before I found a hungry auto body man who did a complete strip, refill (composite body lancair) and repaint for the bottom end of your price target. It can be done.
Lancair 235/340
RV-9A (2013 - 2016)
06-25-2018, 03:31 PM
You might consider doing it yourself with vinyl, or just color accents in vinyl.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
06-25-2018, 03:38 PM
If your aircraft's paint is intact but just faded, you might want to try our SUPERBIRD Aircraft Paint Restoration System that makes your paint - white or colors - bright and shiny once again.
Plus, it's only $99.99, including free shipping in the USA.
Double plus: purchase using the link below and we will make a donation to Doug Reeves/VAF with every purchase!
06-25-2018, 04:28 PM
I haven’t been able to find a Value Painter for my airplane either. I have no desire to tear it down (flying for ten years), so options are limited. Vinyl looks tempting, but in the meantime I just fly high and fast. Nobody on the ground can really tell how bad my paint job is...
Maybe someone wants to do a two for one special lol
06-25-2018, 05:28 PM
I painted both of my first projects in a hangar paint booth made of 2x4s, plastic, furnace filters and a large exhaust fan. The booth will set you back $500 or so if you get decent lighting, I?d guess for an RV-4 the paint will cost $2K (I did both with PPG base/clear).
Ask around - you should find another builder that painted his own plane that can help you. Painting is far easier with two people.
The photo is the RV-10 getting reassembled after paint.
Carl
06-25-2018, 08:03 PM
Is your plane assembled or not?
How many different colors do you want?
How complex is your paint scheme?
All those things impact the price of the paint job.
If it is dissembled, I know a great painter in the Charlotte, NC area, if you want to truck it down to him. The problem with that is you risk damaging it on both trips because he is not at an airport.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-26-2018, 04:23 PM
Paint cost a fortune today so figure that into the cost. Make sure you see a value painters work too cause it cost more to do it over than the first time.
Vinyl will cost you about $2k in material.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
06-27-2018, 12:22 AM
fella just SE of San Antonio did...
..me a great job on an RV9 at a decent price a couple of years ago. he is still in business and i hear his prices aren't bad now either. pm me and i will get you the info cause i am out of the country at the mo...don o.
