Old 06-24-2018, 02:33 PM
Sam Staton Sam Staton is offline
Question Convert dual mag to single mag
My engine is a 6D version - single drive, dual mag. I am curious if anyone knows of a conversion kit that will replace the dual mag with a single. Since I already have electronic ignition, I don?t need two. Sort of having second thoughts about an all-electric airplane. I know it sounds like belt & suspenders, but I think maybe I might feel better if I have at least one dinosaur mag on board. Replacing the accessory case is a non-starter.
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Astronics PPS
Hartzell C/S
Dynon SV1000 & SV700
Old 06-24-2018, 03:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Perhaps a call to Knots2U may be in order. My highlight below.
This is on their web site for ElectroAir certified ignition stuff.
16. My engine has a dual magneto, how do I adapt my engine to use the EIS?
EXPERIMENTAL ONLY! We use a split ring collar on the crank shaft for the electronic ignition timing pick-up. There are some single magnetos that will adapt to the dual mag hole, or alternatively you can operate two electronic ignition systems. Call us and we?ll review the details.
http://www.knots2u.net/electronic-ig...ent-eis-41000/
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2018, 05:20 PM
Hi Sam!---Gil has some good data on this!
Tom
Ridgeland, SC
Old 06-25-2018, 04:03 PM
brooksrv6 brooksrv6 is offline
I had bought a bendix single mag converted to the Dual mag drive from AeroSport Power. I'm unsure of the parts actually changed.
Chris
Old 06-25-2018, 06:08 PM
hgerhardt's Avatar
Default It's all in the archives
If you're willing to dig into this very forum, you can find part numbers of all the parts required. In a nutshell, there is (1) Bendix mag that works, but you have to transfer the original Dual-Mag impulse coupling/gear to the new Bendix (single) mag.
