Originally Posted by Gizmos
If you have a Ray Allen Servo on your rudder, why can't you hook you yaw damper to it?
I suspect that may depend on what the rest of your yaw damper system is designed to control. I don?t see it as feasible with the Garmin avionics as their system uses CAN Bus to communicate with their smart autopilot servo.
I also doubt the Ray Allen servo has the clutch assembly and response speed to work in an autopilot system. The ones I?m familiar with are designed for trim applications which have different requirements.
