Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #71
Old 04-03-2018, 09:27 PM
N96TJ N96TJ is offline
I saw a significant new delay in map redraw for some map features with V5.70, enough so that I thought the software had frozen up at first. It did not seem nearly as bad in V5.90 although I don't have much time on the newer version yet.
Tom Johnson
RV6 @ Chino, CA
Old 04-19-2018, 03:52 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello,
We wanted to give you an update that we have been able to identify and correct the issue that was causing the map drawing delays that several have reported in V5.90 software.
We are working on one additional improvement that we would like to get into the software related to the above report of flashing lights on the GMC 305/307 before we release V6.00.
Thank you for your patience,
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 06-12-2018, 07:11 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Any update on the v6.0 software? I'm still having the occasional flashing lights. Also, when I choose NAV it will not engage the magenta line. Sometimes both the NAV and HDG lights will be lit at the same time and I have to toggle back and forth until it will grab the NAV line.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 06-12-2018, 08:26 AM
g3xpert's Avatar
Post
Hello Anthony,
We expect V6.00 to be released within the next week. We apologize for the delay.
Most of what you describe is normal autopilot behavior. If your active lateral mode is HDG and the plane is not close to and on an intercept path with the course line, when you press the NAV button on the GMC, NAV mode will be armed, but not active.
Simply turn the aircraft with the HDG knob to put the aircraft on an intercept path with the course line, sit back, and watch the autopilot automatically capture the course line (NAV mode moves from armed to active and the HDG light goes out) when the aircraft is close to intercepting the course line.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 06-15-2018, 02:29 PM
g3xpert's Avatar
Post V6.00 Now Available
Hello,
G3X Touch V6.00 is on our website now.
Thanks again for your patience.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 06-16-2018, 07:02 AM
KeithB's Avatar
KeithB KeithB is offline
After the issues with V5.7 (albeit minor), we are all a little less willing to be the guinea pig on a new release - especially a primary one ending in .0. However, I?m less than a week from a 4 week jaunt to Alaska and so I?m doubly shy.
Any PIREPs on this release (absence of problems and/or observations on new features) would really be appreciated.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 06-16-2018, 07:45 PM
hgerhardt's Avatar
Flew once with 6.0 yesterday and the map redraw is definitely faster, although still not stellar. But, it's been so long since pre-5.70 that I can't remember if it's the same as it was before or not. Haven't tried AP performance, so no comment there. Yet.
Old 06-16-2018, 08:09 PM
Walt's Avatar
Walt Walt is offline
About 1.5 hrs today with 6.0, most of the flt with the AP driving, multiple approaches using all modes, 0 issues.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-17-2018, 08:15 AM
Spirko Spirko is offline
The AOA/stall warning tone has been intermittent on my system. I see "Improve AOA/stall warning tone output" in the changes to v6.0, is this likely to make tone reliable?
Old 06-17-2018, 01:35 PM
bkthomps bkthomps is offline
what features constitute a major release for version 6.0?
It looks like mostly small improvements, are there any systems or modules that have received a rewrite?
