Go Back   VAF Forums > The Never Ending Debate Section > Tools
  #11
Old 12-06-2015, 03:50 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Originally Posted by KRviator View Post
How long till someone makes one out of some scrap aluminium?
Then it would be a hand warmer .........
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 06-14-2018, 02:03 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Battery Handle-Every shop should have it
Folks, This is sort of a repost for those who haven't see this great useful tool.
My 3rd PC680 battery died the other day and I had to replace it. I used the tool in the photo and it worked great. Inevitably your PC680 will fail and you will need to extract and install it through the jungle of wires/hoses and other offending obstacles in your way. Don't sweat it and build on of these. You will be glad you did.
Originally Posted by Pmerems View Post
I had a battery issue and had to the pull the battery. When I installed the battery (replaced first one after 4 years of flying) it was a pain to get the old one out and the new one in. This is on my RV-7A with dual impulse coupled mags, battery is mounted on the firewall per van's instructions. I even remember almost getting my fingers caught while trying to support the battery through the lightening holes in the battery box.
I really dread taking the bottom cowl off to gain access to getting the battery out. The PC680 batteries are 15 lbs and aren't the easiest to wangle past the mount tubes, hoses and mag harness so I thought about it for a while can spent about 15 minutes in the shop and came up with this.
It worked great. After removing screws and moving some hoses and wires I installed the handle and lifted that battery right out. Installation was a breeze as well.
I tested this on my old PC680 (still held 12V after sitting on the shelf for 12 months) before I used it on a good battery. No issues.
I wouldn't carry the battery around the shop with this but for installation and removal I would use it again.
I hope someone will benefit from this.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 06-14-2018, 02:47 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
I'd never find it when I needed it so I'd have to make a new one every time.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 06-14-2018, 02:56 PM
Plummit's Avatar
Plummit Plummit is offline
Allan will have the Anti-Splat version out next week, Stay tuned!
-Marc
RV-10
N814RV
2020 Donation Made
