06-11-2018, 09:34 PM
Osprey question
So I returned to my home base at New Kent (W96, Richmond, VA USA) the other day to find that a V-22 Osprey was doing touch-and-goes. Or whatever you would call it when a tilt-rotor aircraft practices landings.
The V-22 is just a flat-out amazing aircraft. I was going to join the pattern and land so that I could watch it in action, but then it occurred to me: what is the wake turbulence like from those things?!?
Fearing it might be extra nasty, I motored on for some additional sight-seeing elsewhere.
Any theories on how much room to give to a V-22?
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2020 Dues Paid
06-11-2018, 10:37 PM
Without having anything scientific to base this comment on: A LOT.
IIRC I read somewhere they have quite a high disc loading, compared to a standard fling-wing. Check out this video of a Blackhawk-induced wake vortex crash in Colorado.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
06-12-2018, 03:01 AM
+1. To quote one of the Indiana Jones movies - You chose wisely.
I was an engineer on the V-22 program in the ?80s (yes it has been around that long). Based on its weight and disk loading give it a good amount of time. A few minutes at least.
-Bob "Beagle" Brents
RV-8 (Reserved: N808B sorta like " BOBB")
(Empennage: 95%)
(Wings: 60%)
?To invent an airplane is nothing. To build one is something. To fly is everything.? - Otto Lilienthal
https://www.facebook.com/fliegen.beagle
Dues Happily Paid 2019
06-12-2018, 07:15 AM
But you have to admit---its a cool thing to watch!!
Tom
Ridgeland, SC
06-12-2018, 07:28 AM
For practical purposes, wouldn't the rotor wash be pretty much proportionate to the flying weight of the aircraft? I understand disk loading, but it's really about moving air mass equal to the weight being lifted more-or-less, right? Or is there something about the tiltrotor that would make it significantly different than say, a Sea Stallion. (I'm lucky enough to see all of these things occasionally at my home field. So there's a practical side to the question.)
Bryan
Houston
06-12-2018, 07:30 AM
I remember the first time I came across one in horizontal flight.
Seeing the size of the props (rotors) my first thought was, "Man, I can't wait to see the landing gear come down!"
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
06-12-2018, 09:11 AM
Treat rotorcraft with respect
The down wash from a helicopter or tilt rotor is nothing to be trifled with in an RV size aircraft. I treat the wake turbulence from a helicopter like I would that from an airplane 5 times larger. Just like airplanes the wake turbulence from a helicopter is worst when heavy and slow, i.e hovering. Anything the size of a Huey or larger needs to be given a wide berth and/or a couple of minutes after it's departure/landing for the wake to dissipate.
Cheers
Nige
Nigel Speedy
RV-8
Flying
Tehachapi CA
I paid my -VAF- dues July 2018
06-12-2018, 02:44 PM
Bad physics
Originally Posted by Low Pass
For practical purposes, wouldn't the rotor wash be pretty much proportionate to the flying weight of the aircraft? I understand disk loading, but it's really about moving air mass equal to the weight being lifted more-or-less, right? )
It?s the force-momentum per second-that needs to equal the aircraft weight. This could be a large air mass moving slowly, or a smaller air mass moving quicker. Same as standing behind a jet or prop plane, when both are producing the same thrust. The jet blast can be felt much further away. Since the design constraints on an Osprey (forward propulsion) drive it toward shorter blades, one can expect significant downward air velocities when landing.
06-12-2018, 06:18 PM
The V-22 is built in Amarillo, Texas and some of them occasionally come to our airport during cross country flight testing. They are really interesting to watch. The downside for us is they throw serious FOD everywhere! They seem to be worse in that regard than the heavy lift fire fighting choppers that utilize our airport, including Blackhawks and CH-47 Chinooks. Their exhaust is also very hot and can start fires in wooded areas.
The wife and I flew to Amarillo for a weekend get away several years ago and as we were flying over Palo Duro canyon we saw a strange looking aircraft at a distance. It took a minute to register what we were looking at. Later as we were taxiing to the runway at KAMA an Osprey came near us and to say the RV was rocking and rolling was an understatement. I was very concerned because I had seen on the news that several people had been injured by one when it knocked down tree limbs in a park it was flying over.
I have great respect for their rotor wash and wouldn't fly anywhere near one!
Here's a video: https://www.youtube.com/watch?v=i4iw2-n-Uzc
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
06-12-2018, 07:19 PM
V22 flyby at Sedona
Agree with recommendations above. Here is one passing through Sedona last year.
https://youtu.be/kQXrUhNU2Ao
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 ( http://gobinkley.com)
Sedona, AZ
