Old 06-08-2018, 12:24 PM
bobnoffs bobnoffs is offline
Default shrink tube battery cable ends
i have done 2 fwf installations and just at the end of this one i tripped on a really slick item. i got some 3/4'' i.d.double wall shrink tube with adhesive. this stuff slips over a terminal AFTER it is installed and crimped on the cable. this stuff shrinks down to 1/4'' i.d. the end result is perfect. only downside is that i had to buy 14' on ebay. send me a buck and i will send a couple 8'' pieces to you. sorry to sound like a cheap smack but i would really like some others to see how slick this stuff is. i will even just send it to show it off.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 06-08-2018, 01:57 PM
Paul Eckenroth Paul Eckenroth is offline
Hi Bob
Sent you an email regarding the shrink tube offer. I would also like info as to where you ordered the material.
Paul
Old 06-08-2018, 02:29 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by Paul Eckenroth View Post
Hi Bob
Paul
Spruce has it. It is usually the good quality 3M stuff with a 3:1 shrink ratio rather than the usual 2:1
https://www.aircraftspruce.com/catal...shrink-blk.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-08-2018, 04:33 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default How
Originally Posted by bobnoffs View Post
send me a buck.
I'm very interested. How do I send you a buck?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 06-08-2018, 08:27 PM
VA Maule VA Maule is offline
Default Sending bucks
Too good a deal to pass up PM me your address and I'll mail you $2.00 bucks postage ain't free
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 06-08-2018, 09:06 PM
G-force's Avatar
G-force G-force is offline
We use alot of the Ancor brand lined shrink tube at work, it is great stuff. The clear liner inside melts as the outer tube shrinks forming a water tight seal. Try your local boat supply shop for it.
Mike Sumner
Castaic, Ca
Old 06-10-2018, 06:04 AM
all gone...........
Bob Noffs
n. wi.
