Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #21
Old 06-05-2018, 07:29 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by Canadian_JOY View Post
Thanks for the quick response, Ross. Now I understand the reference made to those of us with carb'd engines. One doesn't want one's intake hoses to turn to mush, thanks to them being exposed to an air/fuel mixture rather than just the pure induction air associated with a fuel injected engine.
I'm curious... The nitrile hoses you supply. are they any more flexible than the standard Lycoming parts? The Lycoming part seems to be both thicker and stiffer than what is needed for this task.
We are supplying Superior 08-00580 for the 1.5 inch tubes and OEM Lyc PN 69603 hoses for 1.75 inch tubes on carbed engines. I didn't spend much time trying to source other suitable suppliers for the carbed hoses.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 06-06-2018, 05:31 PM
rv6ejguy's Avatar
Trevor was able to squeeze in another batch of flanges today before running other parts booked in a couple weeks ago.
I will run these to the anodizer tomorrow. Thank you to all the people who've contacted us to be placed on the order list. May be able to ship some of these out later next week if the anodizer is not too busy.
Old 06-07-2018, 04:49 PM
rv6ejguy's Avatar
Good news. The anodizer was not too busy so I should have the flanges back by mid week.
Old 06-07-2018, 09:53 PM
Thanks for the follow-up, Ross. I spent most of tonight working on the engine and gave these induction tube clamps much thought... Perhaps they will be on the list for the next oil change.
Old 06-10-2018, 02:55 AM
Toobuilder's Avatar
Concerning the welding of the angle valve tubes- mine were factory welded about an inch down from the flange. I simply cut through the weld with a band saw, replaced the clamps and re welded. With a TIG at the ready, each tube took maybe 10 minutes to modify (not including paint dry time). I did not find it necessary to weld the tube in situ. The band saw cut was easy enough to re index. Really easy.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-10-2018, 05:24 AM
BillL BillL is offline
Thumbs up Thanks!!
I like easy! My TIG work is getting better, but not this ready yet.
Bill
RV-7
Lord Kelvin:
Old 06-10-2018, 12:37 PM
rv6ejguy's Avatar
One of our customers just reported back that the Superior Cold Air Induction setup uses a tube which is expanded out to 2 inches so they are .250 larger than the factory type tubes and aren't compatible.
Old 06-11-2018, 03:37 AM
Toobuilder's Avatar
Expanded out (tapered) at the sump end? If so, then a cut and weld like I did would work?
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 06-11-2018, 05:46 AM
Mark33's Avatar
Mark33 Mark33 is offline
Default Superior sump/tubes
Is there any chance you?ll machine some that?ll work with the Superior sump/tubes? I?m sure there?s enough of us out here that there?d be a market for them.
Mark
Old 06-11-2018, 07:10 AM
Zuldarin's Avatar
Zuldarin Zuldarin is online now
Yes cutting and welding will work just fine. The only thing that needs to change is the size of the rubber sleeve and the clamps. The rest of the tube is 1.75" in diameter. See picture below.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
