I have a different AHRS, so this may not apply to the Dynon, but mine is mounted on a rail directly under the pilots seat just aft of the spar.
This is an optimal location for an AHRS to be as close as possible to center of rotation of the aircraft. Its also easy to access this area for inspection.
My magnetometer is mounted back by in the tail area to get it away from steel...
Just another possibility if the Dynon will fit in that area.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
