05-21-2018, 08:08 AM
Bubble canopy bird strike mitigation
I am just terrified of hitting a bird in flight and having it penetrate the canopy and into my face. This has happened in the past (not yet to me), has been reported here very recently. and will continue to happen. There must be something that can be done to better protect occupants in a bubble canopy.
What comes to mind is application of a tough transparent film on the forward part of the canopy. I know there are films designed to control and contain shards of glass from an impacted sliding glass door. However, these films will not conform to the compound curves of a bubble canopy. There are also various forms of a more stretchy polyurethane tape (colloquially known as helicopter tape and used on leading edges of blades) that is none-yellowing, transparent, and tough.
There has to be a polyurethane film material that can meet the requirements. It won't stop canopy breakage, but will mitigate the shards and impact force to the face. Another solution is to attach a second layer of conformally molded polycarbonate plastic to the aft side of the canopy. Of course, one can always wear a helmet and visor...but a canopy lamination of some form seems more practical overall.
05-21-2018, 09:20 AM
VAF Moderator / Line Boy
Sounds like you need to build a “chicken gun” and do some testing!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-21-2018, 09:25 AM
I have hit a bird in my aa1 and lucky form me it hit the wing. No fun at all. Scary.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
05-21-2018, 09:44 AM
Even if you could stop a canopy from breaking, it will still deform on impact. Considering that most RV canopies are within inches of your head, it's easy to see that you are likely to be injured or knocked out in the right scenario. Short of being very careful and very lucky, I suspect the brute force technique is the most likely to be successful. I came to this conclusion after taking a bird through the windscreen of the -8 and earning a permanent scar thanks to a face full of plexi shards. The replacement windscreen was a shallow sloped flat wrap of .250 thickness. Wont stop a turkey buzzard, but it ups my chances in a repeat. The Rocket will eventually get a similarly sloped windscreen, but it will be .500 thick owing to the higher speed.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
05-21-2018, 10:34 AM
Bird strike is a popular topic in the rotorcraft safety world right now. Use of Wig Wag or pulsing lights is being presented (with some scientific study behind it) as a way to prevent bird strikes. It may be less effective at RV speeds though, I have not read the studies. Wig Wag landing lights may also help prevent large bird strikes (other airplanes) as well...
Bill York
Stellar Airpark (Chandler AZ)
RV-6 N477DH
Eagle II N92CE (sold)
Hiperbipe N777HT (sold)
PA22-160 N9322D (sold)
05-21-2018, 10:37 AM
More than a few people always wear helmets when they fly to protect against birds and other risks.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
05-21-2018, 11:08 AM
plastic film
I've only seen the plastic film used on flat glass or on car windshields. I have not seen if using a bit of heat would help shape it better, or if perhaps using strips would work. This stuff is very tough, that's for sure.
I called the guy that make the thicker windscreens for the RV8, and he essentially talked me out of it, saying that his view is that it won't make a huge difference. I think the plastic film on both sides of a flat wrap windscreen would be the strongest and easiest.
I totally agree that we should find a way to add more protection to the windscreens. Sounds like another business opportunity!
05-21-2018, 03:08 PM
Yep, came within ~50' of an eagle a week or so ago. Not sure if it was deliberately diving on me, came from above. His wing span looked big enough to wrap right around my fuse! Have been wearing my helmet ever since.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
05-22-2018, 11:22 AM
Yeah, what prompted this topic was that during my last flight I had to make an evasive maneuver to avoid a small group of birds, gulls I think. My face is just about 5" from that thin canopy acrylic plastic. I wish it were polycarbonate, although given he enormous kinetic energy of even a small bird I doubt thin polycarbonate plastic will be strong enough. I gotta do something though, but I think that the canopy manufacturers have more resources than I to look into this and to make their own chicken canons. It's a business opportunity for them.
PS- For example, they could at least offer something like a 1 square foot molded section of 1/4" or so thick plastic to mount on the aft surface of the canopy in front of the pilots face. I think that would definitely help.
05-22-2018, 11:32 AM
One could wear goggles.
Flying RV-8 N880BC
2019 Dues - happily paid.
