05-21-2018, 07:52 AM
RV10 Cowling Heat Shield
I have experienced blistering on the interior of the lower cowling from the exhaust stacks. Any suggestions for a permanent fix.
05-21-2018, 10:25 AM
Senior Curmudgeon
Vans has a heat shield product that is designed for this.
Adhesive backed alum foil.
Big thing is to get the inner cowl surface clean, and smooth. A wet coat of epoxy brushed on is a good way to do it. Sand as needed, roll on foil.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-21-2018, 11:23 AM
And then seal the edges with a narrow brushed coat of epoxy or red RTV.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-21-2018, 06:43 PM
Just did this... hope it works, used aluminum tape on the edges as well.
05-21-2018, 10:26 PM
exhaust shields
In addition you could use some of these where the exhaust pipes get close to the cowling.
http://www.aircraftspruce.com/catalo...clickkey=20271
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 650 hrs
OnSpeed development team
05-21-2018, 10:43 PM
For maximum protection, you can use fiberfrax and top it off with the aluminum foil. I had used this in my lower cowl and was amazing how cool the bottom cowl felt to touch even after just shut down of the engine.
http://www.aircraftspruce.com/catalo...SABEgLn__D_BwE
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
05-22-2018, 05:48 AM
If the pipe is really close, the mechanical heat shield on the pipe may hit, mine did. I turned to this method, it is recommended. Kinda like a bandaid, but sealed around the full perimeter.
Bill
RV-7
Lord Kelvin:
05-22-2018, 08:00 AM
I used simple foil tape on the lower cowl interior to reflect heat on my 6A. In close vicinity to the exhaust pipes themselves I used the heat reflective material that I used on the firewall (thermocool, I believe - It is a layer of reflective foil with a layer of fiberglass + adhesive). In other areas, I used a good qualilty (read: thicker than the cheap stuff) aluminum tape. My exhaust gets very close to the cowl and have had no heat related paint issues on my cowl in 500 hours. I extended the foil to cover any area within 6" of linear distance from any exhaust pipe.
Larry
05-24-2018, 07:55 AM
ACS adhesive backed insulation
[IMG] photo 1 by Bill Peyton, on Flickr[/IMG]
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
05-25-2018, 12:04 PM
i also highly recommend getting some teflon tape, and lining the sections where the baffling material rubs against the cowl, you will be amazed at the reduced vibrations transmitted to the airframe
