Old 05-08-2018, 09:13 PM
caapt caapt is offline
Default How do yo compress and flare SS tube?
Working on the exhaust system. 48-03 says fabricate two SS tube. Compress one end and flare the other in a vice. I need more than that. These instructions are rapidly becoming less and less.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Wing Mounted
Inspected and certified 1-31-20
First Flight 3-25-20
Old 05-09-2018, 07:11 AM
bkervaski's Avatar
bkervaski bkervaski is offline
@caapt really, you just squeeze it in a vice to get the approximate dimensions shown. You may be over thinking it a bit. The goal is just to have the end flared enough so that it doesn't slip out of the rubber tube after you clamp it.
You misread that, you are only doing this modification to one end. The vice compression creates a flare. The pic is the same part rotated so you can see what the flare created by the compression in a vice.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-09-2018, 11:10 AM
Aircraft Specialty Aircraft Specialty is offline
What material and diameter/wall thickness is that tube?
Thx much
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
Old 05-09-2018, 11:32 AM
scsmith scsmith is offline
Thx much
Steve
We are not talking about a 37-degree flare here.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 05-09-2018, 12:53 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Something "squeezy" (rivet squeezer with flush dies or a vise)
Something "pointy" and a hammer. (a drift punch is one "pointy" tool)
Mike W
Venice, FL
N164WM
Old 05-09-2018, 12:55 PM
Default UHHHHH
I dont have section 48 of the plans----so what tubes are you talking about? Exhaust hangars?
Tom
Ridgeland, SC
Old 05-09-2018, 12:58 PM
Steve,
You're right...it's not a 37 degree flare. However, an SAE/Milspec tube bead might be an alternative. Another option would be a DIN bubble flare.
There are other areas in the Vans directions that have you create a 37 degree flare and then sand it down to create the bead.
We are just exploring some alternatives and curious to confirm the material (Stainless) as well as the diameter of the tube and the wall thickness to determine if we can create an additional option for builders.
Here is a sample picture of what I am talking about. We didn't do these beads, but it illustrates what I am referring to.
Steve
Old 05-09-2018, 02:24 PM
bkervaski's Avatar
It's just compressing the end of the exhaust support tubes ..
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-09-2018, 05:36 PM
Ron B. Ron B. is offline
I actually made a small flare in the end with the pointy thing and a hammer (center punch and hammer). Put the solid end (before flattening it out) on your vise on a flat spot with the end needing flaring pointing up. Put the center punch in the open hole and lightly tap the punch until the flare you want is made. You just need enough so the rubber hose does not slide off after clamped in place. You can now flatten the other end and drill the bolt hole in it.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 05-09-2018, 07:08 PM
Default I was overthinking it
Once Sterling told me the drawing was two views of the same tube it became clear. Just pinch the end in a vice. I thought one tube was flared and one compressed.
Thanks for the help
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Wing Mounted
