Old 05-08-2018, 05:24 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Automatic Pitch Trim and VPX
Hello
Time to upgrade my TruTrack AP equiped RV-7A with an Automatic Pitch Trim module.
One big question ... does it work in with a VPX?
Because the unit gets joined between the VPX and trim servo, the VPX will see some signal/triggers on the output ...
Schematics here: https://cdn.shopify.com/s/files/1/21...51448760409847
So far I did not got any answer from Vertical Power support ... Hope Chad is reading this.
Thanks for any information ... maybe you are running it allready on your plane.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 05-08-2018, 05:48 AM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by swisseagle View Post
Hello
It works just fine. I've been flying with both for five years.
Wire it like it states in the Vertical Power install manual (5.19c) and the Trutrak install manual you'll be fine. The VP manual only shows the connections unique to it.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-08-2018, 05:53 AM
swisseagle's Avatar
Hello Bob
Thank you!
Ok, my fault not looking into the actual VP manual ... just was reading the TruTrack manual and my "old" VP manual ...
BR
Dominik
Old 05-08-2018, 06:12 AM
Jesse's Avatar
Jesse Jesse is offline
The TruTrak module disconnects the wires coming from the VPX when the auto pilot engages and runs he trim by itself. The VPX doesn?t know the difference.
Jesse Saint
Old 05-08-2018, 06:25 AM
TCONROY's Avatar
TCONROY TCONROY is offline
Yes, the autotrim module works great with a VP-X. You'll have to dial in the setting using the adjustment knob-on the autotrim box, so be sure you have some access to it while flying.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 05-08-2018, 07:28 AM
swisseagle's Avatar
Default Adjustment only once?
Hello Trevor
Do I have to adjust this only once after installation ...
Or from time to time ...
Or during every flight?
Dominik
Old 05-08-2018, 08:05 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Good Question
Hello Trevor
Great question.......I want to install auto trim in my RV-6 and the Auto trim info says to place it close to the servo, which is behind the baggage bulkhead, which is normally only seen during CI's.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-08-2018, 09:22 AM
rleffler's Avatar
Yes, it's just adjusted once. Mine sits adjacent to the pitch servo in the empennage of the RV-10
Bob Leffler
Old 05-08-2018, 03:43 PM
TCONROY's Avatar
I only had to adjust mine on the first flight after installing the auto-trim box and haven't touched it in 3 years.
________
Airbus Pilot
N781TD
RV-7
Construction Log
Old 05-10-2018, 02:33 AM
swisseagle's Avatar
Thanks to all that responded ... waiting for the auto trim to arrive!
Dominik
