  #21
Old 03-27-2018, 02:10 PM
DHeal DHeal is offline
In addition to the RotaxOwner videos, there are a couple of videos on YouTube that depict the servicing of Bing carbs -- not necessarily by the book but they do have some good visuals of the carb's internals.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 03-27-2018, 02:23 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by DaleB View Post
Is there a compelling reason to ship them off to let someone else overhaul, or is this a no-brainer for guys who have some clue which end of the screwdriver is pointy?
No-brainer.
CV Bings are very simple, and have not really changed in 40 years.
Worst case, you throw them in a box later and ship them to a shop.
FYI...We lost a 2 stroke Kitfox here some years ago and traced the fuel stoppage to a small piece of trash hidden in the carb's fuel inlet nipple, i.e just upstream of the the float valve. Nobody ever looks there.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-21-2018, 06:26 AM
todehnal todehnal is offline
Originally Posted by bob1393 View Post
Thanks Scott and others for the reply. We have the new floats and did check them at 200 hours and they were fine. We did not check them again at 400 hours. We will check them now and the gascolator also to see if there is any debris or contamination as well as weigh the floats.
Bob
Hey Bob, Were you successful in solving your carb problem? I have the same problem and I am currently working on it........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 04-21-2018, 03:39 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I ran into the same issue in December and did an engine shut down and power off landing. Went through many carb clean/flush with no debris evident. Ended up draining all auto gas and switch to 100LL with fuel system flush. No problem since. Was thinking old ethanol gas had some fuel line deposits.
Scott- 2020 donation
New RV-7A N579RV, only 80 hours now without 2020 fly-in destinations
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
Old 04-21-2018, 09:36 PM
bob1393 bob1393 is offline
Todehnal - next morning it started and ran perfectly. We did swap out the Ducati Voltage Regulator. We've been flying it and have not had any issues. I'm thinking dirt or debris in fuel line someplace or in the carb that has worked itself through. We're coming up soon on the 500 hour inspection and we'll see what we find. Let me know if you uncover anything.
Bob
Old 04-22-2018, 01:00 PM
Hey Bob, glad yours is running well. I'm still in trouble here. I replaced the plugs, pulled the float bowls and inspected. I did adjust the fuel level slightly. Those were the easy things. Next, I plan to pull the carbs and do a tear down inspection. From the replies that I've received, most suggest that the likely suspect is a carb problem. It is hard to diagnose. You would think that a shut down and inspection of the plugs after a rough run situation would point you to the problem. Apparently that is not the case with Rotax. I understand that the rough running shakes the **** out of the carbs, the floats go nuts and flood everything. In my case, all four plugs in cylinders #1 and #2 were totally sooted up, as was the tail pipe. I will post any finds...........Tom
Old 04-22-2018, 01:50 PM
Also check for debris in the return fuel line metering orifice.
Old 04-22-2018, 03:40 PM
Now that does surprise me that this could cause a rough engine, but it is an easy check. Thanks.....Tom
Old 05-05-2018, 08:03 PM
Art_N412SB's Avatar
Art_N412SB Art_N412SB is offline
Default Its all better now.
This is Art, one of Bob's partners. The problem with our rough running engine was some contamination in one of the carb float bowls. We think the contaminant was from chaffing of one of the floats. Keith (one of the three owners) found a small initially hard object. After extracting it from the float chamber he was able to crush it between his fingers. We think it would intermittently clog the jet causing the engine roughness. We have flown several hours since without any problems. Also, Lockwood in FL was very helpful in steering Keith in the right direction.
