Old 05-05-2018, 12:57 PM
Cyclone Cyclone is offline
Default ELT Install
I'm installing the E-05 ACK ELT. With the cockpit dash remote plugged in to the audio alert strapped to the ELT, I get a low chattering/clicking tone and an ELT "ON" light constant flashing on the dash. Push and hold the ON or RESET button and the sound and led light goes off. Acts the same with or without the cables hooked up to the ELT. Batteries test good.
I'm not hooked up to aircraft power yet, could that be a cause. Leaving the ELT in off position to keep the black helicopters away
RV12 - Flying August 2019
Restoring 1967 Ford pickup - no amount
of money will make this thing fly.
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 05-05-2018, 07:03 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
The wiring is the problem. Many have had the same issue. Cut off one of the phone jack plugs and install new plug with wires flipped. This will solve your problem.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 05-06-2018, 07:12 AM
Thank you for your help. Always some consolation when it?s someone else?s
screwup rather than my own.
