Old 04-30-2018, 10:56 PM
Phil's Avatar
Phil Phil is offline
Default Another leaky tank thread
I have a rivet that that would prefer to have the fuel on the outside of the tank rather that the inside. I've begged it to stop and it won't. So I tried the Lock-Tite trick with no success. I went on to try forcing some proseal around the existing rivet and still no success.
At this point, before I take the tank off to cut a hold in the backside, I'd like to try a blind rivet nestled in a bed of proseal.
So here's my question: what rivet seems to the rivet of choice for such an application? As should be expected, it's a #40 dimpled hole.
Phil
Old 04-30-2018, 11:28 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Call Vans, they keep a sealed end pop rivet in stock.
I did this, and it worked for my leak.
Good luck with yours......
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-01-2018, 09:21 AM
acam37's Avatar
acam37 acam37 is offline
If you come to Nacogdoches (KOCH) I have plenty of those sealed rivets and tank sealant. I fixed a leaking rivet on my -8 without having to remove the tank
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 05-01-2018, 10:19 AM
pa38112 pa38112 is offline
What happens to the inside piece of rivet that remains after you drill-out and break off the head? Do you still remove the tank and then retrieve that?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 05-01-2018, 10:24 AM
acam37's Avatar
Left it in the tank. Most likely it stayed embedded in the tank sealant when the bit pushed through. If not, It would have to get through two sets of screens and a fuel filter before it gets to the engine. No chance of that small piece of a -3 rivet would stop up a fuel line.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
KOCH Nacogdoches
Old 05-01-2018, 10:33 AM
Mike S's Avatar
Senior Curmudgeon
These are sealed end rivets, the broken off piece stays inside the closed end of the rivet. Here are a couple images my friend Mr. Google found....
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-01-2018, 11:11 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I think the question is what happens to the shop head of the drilled out AN426AD-3 rivet. The manufactured head snaps off, you push out the shop head, put in the sealed blind rivet, and then the shop head pushed out earlier goes ... ?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-01-2018, 11:19 AM
Mike S's Avatar
Senior Curmudgeon
Brad, upon re-reading the question I have to agree with you--------my bad.
I did not remove the shop head, and did not have any issue because of it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-01-2018, 11:22 AM
Carl Froehlich's Avatar
Most likely if you are careful the end of the orginal rivet will still be stuck in the proseal used during tank construction. Even if the end drops in the tank, the pickup strainer will keep it there.
I?ve done this fix on three tanks - simple and it works. I do use a vacuum for the rivet drill out, drilling the hole to #30 and the minor countersink to accept the sealed end blind rivet. Have the fuel level in the tank below the rivet to be replaced. Put a little proseal in the hole after prep, then on the rivet itself. Once do no one will know it is there unless you point it out.
Start to finish is 15 minutes. Let the proseal set up before exposing it to fuel.
Carl
Old 05-01-2018, 03:22 PM
9GT's Avatar
9GT 9GT is offline
Quick Build wing tanks or are they standard kit built?
David C.
Howell, MI
