  #41
Old 03-25-2018, 05:50 PM
Dave12 Dave12 is offline
Originally Posted by PilotBrent View Post
Add me to the list of broken brackets. Saw it this weekend (420h) but it may have been there in the past and I never noticed it. Credit this post for even knowing where to look. Really don't think I have excessive vibration although I've never had the propeller balanced. Might be an argument to do that.
Never balanced eh?
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 03-27-2018, 07:43 PM
FYI my prop was dynamically balanced and the little bugger still broke!
Old 04-29-2018, 09:05 AM
PilotBrent PilotBrent is offline
Been meaning to post this. I went ahead and fabricated a very basic replacement ignition coil bracket from some scrap aluminum angle I had in the hanger. But, before installing it a friend at the airport dropped by, who has a machine shop and also an amazing basement workshop, and insisted that we fabricate a more durable replacement out of 4140 steel that would be less prone to break again. I shot this short video for our EAA chapter (we're going to visit his basement in a few months). He added a third side to the bracket to strengthen it, but (not in the video) I needed to remove much of that in order to be able to get a small wrench in there to reinstall the bracket on the engine. Those of you have have had to make this repair know how tight it is in there.
Over engineered. YES. But was really interesting to see a skilled machinist in action. After weeks of maintenance in abnormally cold spring weather, several SBs, and this last repair, the annual inspection that wouldn't end is finally done...
P.S. if you check Lockwood's website, the replacement bracket (# 851260) can be purchased for something like $11 (surprisingly cheap compared to most Rotax part prices). So if this one fails, I'm obviously just going to buy the next one.
https://youtu.be/dFLTrf4WRl4
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 04-29-2018, 05:42 PM
I don?t think that one wil break pal! Obviously this is the gent you were telling us about?
Old 04-29-2018, 09:10 PM
wjb's Avatar
wjb wjb is offline
Great video! I'd love to have access to a shop like that.
Bill Bencze
Old 04-30-2018, 06:02 AM
If it?s who I think it is, all that great equipment is in his basement. Impressive!
Old 04-30-2018, 09:39 AM
EXflyer EXflyer is offline
Default Bracket
I see a great item taking care of a problem nothing over engineered here just done to fix a problem like Rotax should have done years back. The metal remaining is more than enough to take care of the problem. Well done and hey guys, a small milling machine and a mid sized lathe are in my garage and have been used on many things other than my large scale trains.
Old 05-01-2018, 09:18 PM
My German cousin is a ROTAX mechanic. He got me a couple of replacement brackets, and he said this issue is not common to other aircraft types. Seems weird we are so ?blessed? in the RV-12 world.
I took all the dimensions on the ROTAX parts so I can make replacements in the future.
Old 05-02-2018, 01:54 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
It looks like most ignition mounting bracket failures are the stubby 90 degree brackets on the back of the ignition coils. I have not had this failure, but now at my latest oil change (325TT), I noticed the long front bracket has failed just below the 90 degree bend. This is PN 29 in the attached drawing. The bracket is 0.080” Stainless Steel. I have fabricated a new bracket from 1/8” mild steel and added 1/8” to the overall width for additional strength.
Attached photos show broken bracket and 1st iteration of new bracket to test fit. A second more professional bracket is now installed on the engine.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
Old 05-02-2018, 06:33 PM
It?s a shame you don?t know Brent?s buddy.
