Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 04-25-2018, 10:21 AM
iamtheari iamtheari is offline
Default Panel dimmer or not? (Garmin)
I am planning to use the G3X Touch in my RV-14. The devices actually visible on the panel will be a 460 (PFD) and a 465 (MFD), a G5, a GMC 507 autopilot control panel, and a GTN 650 navigator. Power will be supplied by a VP-X Pro. I just got the fuselage kit today, so of course I have spent the past month planning out the panel wiring harness.
My understanding is that the screens I will be sitting in front of all have an auto-dimming feature based on ambient light and that wiring up a manual dimmer circuit is optional.
For those who have similar equipment, do you have a panel dimmer? If so, do you feel it was worthwhile? If not, do you wish that you had one?
Old 04-25-2018, 11:01 AM
Bavafa Bavafa is offline
I am in the same place and my question/research has shown that they are all self dimming and no external dimmer is needed. I hope I have not got the wrong info and would love to hear confirmation on this.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 04-25-2018, 11:35 AM
pilot2512 pilot2512 is offline
I am wiring up the dimmer. My research on Van's seems to show that there are times the sensor my not sense the light properly (such as low sun angle) that may cause more light on the screen but not necessarily the sensor and it might be to dim. Nice to be able to reach over and adjust it where you like it. Just another data point.
Jay
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 04-25-2018, 11:42 AM
Walt's Avatar
Walt Walt is offline
I install dimmers for the big screens and GTN units on every panel upgrade I do because that is what I personally prefer, when flying at night I like my panel stuff at minimum brightness levels and going into a menu to do that is not a priority, just easier to twist a knob and adjust to your liking.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-25-2018, 12:11 PM
Kentsrv7a's Avatar
Kentsrv7a Kentsrv7a is offline
I wired the dimmers but still use the auto dimming feature on the 460's, G5 and GTN 650. They all work fine but I do find the G5 reacts slower than the others. It takes several keystrokes in the menus to change over to the manual dimmers. I wired mine through the GAD 27.
Kent Stitt
[size="1"]RV-7A
TMX-IO-360w/ P-Mags, Hartzell CS Prop, Slider,
Dual Garmin G3X Touch w/ GTN-650
Old 04-26-2018, 08:44 AM
rvsxer rvsxer is offline
Virtually all Garmin panel-mount units feature photocell-controlled lighting that can be profiled. In practice, it works very well. One thing to remember, however. The Garmin panel-mounted audio panels need a dimmer input for the backlighting, so if you have one you should install at least one dimmer. You could also provide a fixed voltage input to it and switch a resistor into the circuit with the nav light switch for a dim position.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 04-26-2018, 09:48 AM
Thanks for the tips. A thought I had is that the only time being able to see what's on the panel would become a true safety of flight issue is when the natural horizon is not visible. For me that means IMC or night. (Mountain day VFR could qualify as well but I'm not a mountain pilot...yet.) At night, the photocells will almost certainly figure out it's dark. That leaves IMC.
Has anyone had issues with the photocells while flying in the clouds or other IMC?
Another factor: Do the certified equivalents of these Garmin products require dimmer knobs in a conforming installation?
Old 04-26-2018, 09:52 AM
Walt's Avatar
Not so for the GMA245:
Photocell dimming circuitry automatically adjusts the brightness of the annunciators.
Backlighting is controlled by the aircraft lighting bus inputs if the lighting bus is connected.
If the lighting bus is not connected, backlighting is controlled by the photocell.
Old 04-26-2018, 10:48 AM
Aluminum Aluminum is offline
Walt, if not too much to ask, can you provide link to the dimmer unit you use?
Can any of the Garmin equipment be configured to be a dimmer "master", i.e. to provide voltage output from the photocell for the other units and non-Garmin equipment?
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
Old 04-26-2018, 10:58 AM
Walt's Avatar
I just use 10K pots, simple and reliable, one for the G3X and one for the 650. I believe the GAD27 can be used as a dimmer master to control other stuff.
