  #11
Old 04-24-2018, 07:32 AM
RandyAB RandyAB is offline
Originally Posted by Kyle Boatright View Post
The green version is/was the original.
Sounds like you have the latest. Does your top have a sticker with "inspected on xx/yy/zz" printed on it? If so, what's the date on the sticker?
Not currently Kyle. I might have removed it though. I got it with my quickbuild back in Sept.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 04-24-2018, 07:39 AM
My cabin top was all pink and was manufactured in 2016. I think you have the more recent version.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-24-2018, 08:29 PM
sritchie sritchie is offline
Originally Posted by Electrogunner View Post
What I did
- I fit and clecoed the top secure.
- trimmed and fit doors,latch/pins and fit the mc master door seals and door gutters, fit all windows but not glued
- took top back off smoothed and painted interior of top including glueing and clear coated overhead console. Painted all exposed interior surfaces of fuselage with final color.
- permanently attached top to fuselage.
- fit all avionics racks and panel to forward fuselage top while on bench.
- fit and installed parking and heat cables and installed firewall pass through
- permanently installed forward fuselage top and installed all windows
- glassed in windows and built windshield fairing and started blending doors to top and setting door gaps.
- took break from fiberglass and worked on harness and panel install and wiring every now and then to break up the monotony of filling and sanding.
This process worked well for me and was the most efficient way I could think of.
Interesting, this is great. And I guess you're waiting to paint the inside of the doors until after the door blending and gap-setting?
Old 04-25-2018, 07:08 AM
Electrogunner Electrogunner is offline
Default Door paint
That is correct
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
