Originally Posted by falcon900guy
I?m using Infinity grips on an Aerosport symmetrical panel and researching what some have done to the sticks. Cut off some stick up top, at bottom of stick, or bend stick. What has been successful?
As you noted, people have done all of the above.
I cut about two inches off the back of the stick. Basically up to where the powder coat starts. The does bring the stick closer to you, but I've not found that to be an issue.
I also cut a bit off the top so that that the grip will go further down on the stick. You may have to adjust some of the holes to make the grip fit properly.
I also installed stops on the elevator. Please don't install any stops until you measure and ensure that the elevator travels exceeds the specifications from Van's.
I have the original Aerosport panel. The passenger stick still can hit the right corner of the radio stack, but that really isn't an issue. I've I have to apply full forward stick, I'm really having a bad day.
