04-22-2018, 06:03 PM
Milling work needed...small job
Hi everyone,
I need two small disks made from aluminum.
OD: 1-3/4"
Thickness: 1/16"
These will be attached to the front gear fairing (RV-10) where the tow bar attaches so that the tow bar won't bash/scratch the fiberglass.
I had these before but they popped off in the cold...so I need couple more (and some better way to attach, lol).
If anyone out there has an idea where I could get these or if anyone has the ability to make them, I would really appreciate it.
Scott
Scott Martin
N430WP RV-10 - Purchased
04-22-2018, 06:21 PM
Use 3M 5200 as the adhesive next time... they will never ever ever come off. You can buy a small toothpaste tube size from Lowe?s for about $5.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
04-22-2018, 06:31 PM
been here awhile
04-22-2018, 07:31 PM
You could easily make your own using two sizes of hole saws. Cut the big hole first, then cut the small hole in the disc. Holding onto it is a little tricky - maybe make some plywood plates to sandwich the disc.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
04-23-2018, 12:29 AM
I would cut the small hole first, then cut out the piece (big hole) while you have something to hold on to. Use a piece of wood under the aluminum to center the drill pilot.
-Marc
RV-10
N814RV
2020 Donation Made
04-23-2018, 06:45 AM
Double sided carpet tapes works great for this kind of stuff. Use a piece of plywood or flat board as the backer.
David C.
Howell, MI
04-23-2018, 06:50 AM
I would be happy to machine these Al parts for you. If you would like to PM or email me your contact and shipping information.
Ian
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 2%
2020 VAF Gladly Paid
04-23-2018, 10:16 AM
I'll see your carpet tape, and raise you some masking tape and superglue  . (thinner firmer stackup)
Scott Card
CMW E-Lift
04-23-2018, 10:18 AM
How well does a flat washer that size match the very slight curvature of the nosegear fairing?
I'm looking for just this solution, but want something that doesn't stand out as being a kludge.
2019 Dues paid!
04-23-2018, 10:43 AM
been here awhile
Bend the washer???
