04-21-2018, 09:54 PM
RV8 4 pipe exhaust - who uses?
My engine is IO-360-A1B6 angle valve with 10:1 pistons. The recommended exhaust is 4 straight pipes. No crossover and no 4 into 1. Idea is better cabin heat and less crowding around throttle/mixture cables plus power.
Any other RV8 out there with 4 pipes? Hows the room at the cooling ramp exit?
Other issues?
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
04-22-2018, 04:48 AM
Steve, I have one on my parallel valve IOX-370. Plenty of room around the cowl exit. I also have my breather and sniffle valve plumbed to exit in the same area and there's plenty of room.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
04-22-2018, 06:15 AM
I have a 180hp IO-360-M1B with 4 straight pipes. There's plenty of room around the cowl exit.
N29213 - RV8 completed 2017
RV10 - started 2018, final finish work now.
Columbus, IN - KBAK
04-22-2018, 07:03 AM
I used Vetterman's 4 pipe on my IO375. Here is a during construction photo of the exit. Its hard to tell in the picture but there is plenty of clearance to the cooling ramp and lots to the cowl as the picture clearly shows. You can see the crankcase vent above the exhaust pipes. Sounds good, is simple, and there is plenty of area for cooling air flow. FYI I also hung the pipes off the engine rather than the engine mount.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
04-22-2018, 07:04 AM
4 Pipes
I have IO-360, parallel valve with the 4 pipe system. Plenty of room for things in the cowling. Plus folks tell me the plane Sounds better 😜 than the other RV?s on the field with other styles of exhaust.
John Goodloe
RV-8. N6279G
Pay in November
04-22-2018, 08:46 AM
4 pipes
Question for the 4 pipe guys....no thread drift.........
Does each pipe have a slip joint or ball joint?
and so are there 4 hangers too?
4 pipes coming out the back seems very cool...
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
04-22-2018, 09:09 AM
On mine each pipe has a slip joint and a ball joint.
N17BJ
RV-7 Tip Up slow build
200HP IO-360-A1B
Hartzell CS
Working on wiring and Fw Fwd
Got my RV-7 tail kit for X-mas 2012
Guess the Wife's on board!!
Dues paid 3/11/2019
04-22-2018, 09:57 AM
For better cabin heat, might want to call or email Clint at Vetterman and discuss the relative benefits of a trombone exhaust and any power differences.
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
04-22-2018, 12:34 PM
Two pipes get combined on one hanger by way of flat bar clamps (provided by Vetterman) - so two hangers.
Dennis Enns
Kingsville, ON
2020 Donation In
04-22-2018, 07:33 PM
I do have the Vetterman 4-pipe exhaust for my Superior IO-360-X... but haven't installed it yet. So I suppose I shouldn't comment. Yet, here I am... commenting. Sorry about that.
