Old 04-15-2018, 08:10 AM
roofus4 roofus4 is offline
Default Structural effects of Rosen Sunvisor?
At Sun-n-Fun, I picked up a pair of Rosen Sunvisors, but made sure they are returnable, because I?m concerned about the structural affects it may have on the roll bar. They are only for the -6,-7, and -9 sliders, and they require drilling two holes in the rollover bar. The holes would be large enough to accommodate an 8/32 riv-nut. Has anyone installed these in their plane, or does anyone have any thoughts on the effects this may have on the rollover bar?
If you have installed them, how do you like them?
https://generalaviationnews.com/2014...nopy-for-vans/
Thanks Guys
Old 04-15-2018, 03:08 PM
Larco's Avatar
Larco Larco is offline
Thanks Guys
Probably no more affect than the handle install?
Larry
Old 04-15-2018, 09:36 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Check the instructions. I installed mine a year ago and don’t recall rivnuts. I think I threaded the roll bar tapping a 1/8” hole. And I’m no engineer but it’s steel and strong.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 04-15-2018, 11:12 PM
Originally Posted by pilotkms View Post
Check the instructions. I installed mine a year ago and don?t recall rivnuts. I think I threaded the roll bar tapping a 1/8? hole. And I?m no engineer but it?s steel and strong.
That?s interesting. I?m just going by what the guys at S-n-F told me. I haven?t had a chance to dive into the instructions yet. Thanks for the guidance.
Btw, how do you like them? Do they get in the way when not in use?
Old 04-16-2018, 06:41 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default YMMV
I installed them and ended up removing them as they never seemed to be where the sun was. After a few years they started to droop occasionally also.
Would be easier to just put a strip of the sunshade film you can buy across the top like they have in cars. I have this on the slider portion either side of the center rail and it works well.
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 04-16-2018, 07:49 AM
Jpm757 Jpm757 is offline
I agree that you are better off drilling and tapping, rather than installing aluminum rivnuts. I have never had any luck using rivnuts, they require a large hole, and invariably strip out and or loosen after time. The rivnuts will not hold up to the constant movement of the visor.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 04-16-2018, 08:17 AM
Awesome info guys! Thanks! I got them on a whim without doing much research because of the show price at Sun-n-Fun and they told me I could return them if they are unused. Sounds like my $400 would be better spent elsewhere...
