James,
Leave last 3 inboard ribs out to improve access, just make sure you get every rivet even at the skin to spars before you move to the next rib working yourself out to the inboard rib. You may need to remove the skin rivets at the rear spar flange to allow next rib to slip into place.
Roger Graham
Lubbock TX
RV-4 Under Construction
VAF Dues Paid 2018-2019
