Old 04-14-2018, 07:26 AM
bomber_JB bomber_JB is offline
Default Receiving quick build fuselage & wings
I'm due to receive RV-10 quick build fuselage & wings in about 7-8 days. It's coming by Partain Trading Co. contracted to Stewart Transport. Truck will be a full size semi truck/trailer with a crane mounted in roof of trailer.
Fuselage & wings are not crated.
Need some insight into this method of delivery. Driver will assist but that probably means he operates the crane only. Is that correct?
If driver operates crane will two people be enough to maneuver these items?
I'm thinking I need to premake wing slings/racks and fuselage racks (with wheels) to go straight from truck (crane) to racks and then wheel into hanger.
Van's is closed at the moment so I can't ask them but are there some designs (pictures or drawings) of the wing slings/racks and fuselage racks I can use?
Would appreciate any insight from those that have traveled this path before me.
Jerry
Old 04-14-2018, 07:37 AM
The driver helped unload when my fuse was delivered. There was no crane.
The wings can be carried by 2 people, but the fuse is pretty heavy to carry very far for 2 people. Access to a wheeled dolly at curbside is a good idea. There was a thread earlier this week where I posted a picture of the dolly I used on my QB. That would be a good start.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-14-2018, 08:20 AM
Default Delivery
I received my QB wings and fuselage from Partain. Definitely build the wing cradles before they get there. Search the forums and you will find drawings and dimensions. The cradle I built holds both swings and it is on casters so I can move them around.
The fuselage will be heavy. They packed all the rest of the kit INSIDE the QB fuselage, I found that two guys would have a difficult time managing it. You could either unpack it or get a couple extra guys. I also made a rolling cart to set it on.
The driver also helped me unload but there was no crane. It was delivered via an enclosed trailer with a fold down ramp.
Make ABSOLUTELY sure that there is no damage before you sign the BOL. if there IS damage, note it and take lots of pictures. Hopefully, there won?t be any but...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 04-14-2018, 07:06 PM
karrelsj karrelsj is offline
The Partain driver helped me bring the fuse into the garage, but his truck overhead hoist was broken. We drove around looking for a new parts for his hoist, but we ended up offloading it by hand. I wouldn't recommend what we did (take the fuse off the truck by hand with two guys), but once things are out of the truck two guys are enough to move things around. We did unpack the fuse before we moved it.
RV-10 under construction
Old 04-14-2018, 07:11 PM
bkervaski's Avatar
bkervaski bkervaski is offline
The driver that delivered mine was more than helpful, careful, and not in a hurry. He had a hoist that he used to lower the parts. The fuselage was moved using a flat cart and we just carried the wings, they were manageable.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-15-2018, 04:54 AM
soloff soloff is offline
Definitely agree with the posts above. Building the wing cradles beforehand was a must! I built a rolling stand for the fuselage but I ended up not using it. The fuselage came on a high quality pallet that I just reused as my fuselage stand by installing large caster wheels on the bottom of the pallet.
The driver will have a carpet covered cart that we used to roll the fuselage down my driveway. It was easiest to just have 2 people carry the wings to the wing cradle.
If you can get a couple guys to help you with the unload that is ideal. If you're on your own the driver was so nice that he was happy to have helped out more.
I would give him a tip depending upon the level of extra moving work he helps you with.
When everything is at your house you'll be excited to jump right in and start building but spend the first week or two fully inspecting every step of the QB kits and inventory all of the parts you receive. It will save you a lot of time down the road.
Scott
RV10 fuselage and tail finished. Closing up wings.
2020 Dues Paid
Old 04-15-2018, 07:01 AM
It is probably worth contacting the driver before you make any assumptions. My fuse didn't come on any sort of pallet and the driver didn't have a padded cart.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-15-2018, 01:05 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Partain delivered my QB kits via Stewart Transport in a Factory Five trailer with a crane. The driver, Don Furr, was very helpful; he had a large rolling dolly and got his truck much closer to my house than expected. It was in the middle of a ice storm and the road & driveway were solid ice, but we covered the parts in plastic and got everything in ok. The Factory Five trailer inspired some jest amongst my crew. One said "Looks like you got the wrong delivery!" I answered "Fine by me; I'd love a Factory Five Cobra. Instead of getting my engine from Barrett, I'll get it from Roush!"
Kind of odd now that I think of it... my QB kits were delivered in freezing rain; I drove through freezing rain enroute to Barrett for my engine... and today on the way to Whirl Wind in OH to pick up my prop, I drove through freezing rain. God's telling me it'll be a cold day in **** when I finish my RV-8. So.... bundle up down there!
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 04-15-2018, 02:22 PM
wirejock's Avatar
wirejock wirejock is offline
Default Welcome
Jerry
Welcome and congratulations.
I manage a Google Group of Vans Builders/Owners in an around Colorado (also a few outside). Currently 20+. Every model is represented including the RV10.
If you would like to join, send me an e-mail from a Google Account. My e-mail address is in my signature.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-03-2018, 05:10 PM
Glen P Glen P is offline
Partain doesn't cross the Canadian border so I'll be meeting his driver in Niagara Falls, NY with a U-Haul truck. I got some advice from Bryan Hathaway at Van's on how best to strap things down in the truck. Has anyone else done this? I've built carts to receive the wings and fuselage in the hangar but I don't think I'll use them in the U-Haul. Any thoughts on this?
Glen Palmer
Toronto, Ontario
Working on the -7 FWF kit
Dues paid July 2020
