Old 04-12-2018, 05:18 AM
ctennis ctennis is offline
Default Repeat offender time between builds
For repeat offenders, curious what your time between finishing project A and starting project B was? I was at nine months before I pulled the trigger on the -10. My wife's eyes rolled deeper than I think I've ever seen.
N29213 - RV8 completed 2017
RV10 - started 2018, final finish work now.
Columbus, IN - KBAK
Old 04-12-2018, 11:15 PM
Aluminum Aluminum is offline
Can't say project A is ever really finished, but: four years and hundred Hobbs since airworthiness until putting in the order for B on July 4th. The itch wouldn't go away. All better now. My main gripe at the moment: B is coming together way too fast and easy--A took fourteen years.
Explain to wife patiently that it's a hobby, and that it helps you stay away from drugs and crime.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
Old 04-13-2018, 04:02 AM
Kyle Boatright Kyle Boatright is online now
15 years. I was a bachelor during the RV-6 build, which made things much easier than they are now. With a family, it is recommended (by my wife) that I not do things like store wings in the master bedroom and the canopy on the dining room table.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-13-2018, 07:32 AM
Carl Froehlich's Avatar
Six years between the 8A flying and starting the 10. Four years between the 10 flying and starting the 8.
Selling the RV-10 was a big mistake. I may have to build another one depending on son and son-in-law wanting a plane (both are Naval Aviators).
Carl
Old 04-13-2018, 07:25 PM
Jpm757 Jpm757 is offline
I completed an early -6 slow build kit in 1991, took 2 years. Just completed a -7 QB in 14 months. I prefer not to drag these projects on for an extended period of time, but rather dedicate the time and get it done. I have to admit that I am not strapped to a normal 9-5 job, and probably have more time available than most. I have found with any big project that working just an hour or 2 at a time can really drag it on. When I go down to my shop it takes me probably an hour to get "up to speed", then I try and work for 8 hours or so. Much more productive! I also try to order everything I think I will need in advance so it is there when I am ready. Things like FWF kits, drop in interiors and pre wired avionics can really speed up the process. GOOD LUCK!
Just got back from Sun n Fun, Great WX thursday, great RV turnout!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
