Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Closed Thread
  #11
Old 04-06-2018, 08:58 PM
WB-avl WB-avl is offline
Default Reference?
Originally Posted by BobTurner View Post
That?s not the way it works. Your ADSB-out signal tells the ground station what frequencies you?re listening on. The ground station will not send up traffic that it thinks you should be receiving directly.
Do you have a reference for that statement?
William Byrum
Asheville, NC RV-7
getting there...
2020 VAF supporter
  #12
Old 04-06-2018, 09:43 PM
Originally Posted by moosepileit View Post
UAVIONICS wingtip and tail WAAS GPS receivers and Nav position lights are 978 UAT transmitters, right?
They only transmit via UAT on 978 MHz to ground stations, not other aircraft, right?
If you want to see or be seen air to air via transponder you either need the other guy to have a 1090ES transponder and you to have a 1090 ADSB-IN solution to see him and you to have the same to see you, air to air.
Otherwise you need full up TCAS or you are depending on FAA retransmissions from the ground.
I'll likely put this newest Uavionix offering on our 6.
Pun intended...
The 978 transmission is intended to be received by ground stations AND other aircraft who are listening on 978. The ground stations are supposed to send your position up to participating aircraft who are listening only on 1090.
  #13
Old 04-06-2018, 10:18 PM
Here’s one:
Data you requested is near the bottom.
https://www.faa.gov/nextgen/equipads...ties/ins_outs/
  #14
Old 04-07-2018, 07:38 AM
moosepileit moosepileit is offline
Thank you. I surfed around after seeing your reply and now agree and feel even better about using this 978 Out solution. Would like to see a few good PAPRs and no bad ones!
RV-6, bought from builder.
O-320, slider, carb, mags, FP
  #15
Old 04-07-2018, 09:36 AM
Snowflake's Avatar
Originally Posted by airguy View Post
Line-of-sight radio transmission being blocked by "stuff" in the way is only applicable at fairly appreciable distances. Anything close enough to you to worry about, but directly above or below, is going to be sending a powerful enough signal to be seen on the other side of your aircraft regardless.
That is good to know, but still I think it supports my concern... I want other aircraft to know i'm coming as far in advance as possible. If I have a weaker signal cone pointing along my direction of travel, that reduces the range at which I should be detectable. If i'm flying towards an ADS-B tower, or straight at another airplane that I haven't seen yet, we'll be closer before we get alerts.
Still, it depends on the definition of "fairly appreciable distances". If they're above or below, I don't care because i'm not going to hit them. If they're off to one side, my signal should be good and there should be reduced probability of intersecting flight tracks. It's the head-on (or near head-on) traffic that we encounter more as we devolve to following the magenta lines that worries me.
Rob Prior
  #16
Old 04-07-2018, 11:38 AM
airguy's Avatar
airguy airguy is offline
Certainly true. I wouldn't think it would be attenuated enough to be a concern within the range of collision-avoidance distances, but only testing would tell us for sure. Each airframe will have more or less sensitivity to that.
  #17
Old 04-07-2018, 07:22 PM
flightlogic's Avatar
Default misundertood?
I am not sure if I am reading the comments about being seen in front correctly or not???? In my observation over some years now.... LED position lights don't really do much in the daylight. I have pretty bright lights, but only the landing lights are focused enough to do much in daytime. Blinking helps as well as wig wag. As far as ADS-B is concerned, there is no difference where it is mounted. It is a data link. Your ship position is reported via data bursts. Most of my flights, I notice I am hitting four or five towers at varying distances. My position is being reported and all the traffic around me is able to determine on their own datalink receiver, where I am. We have an inordinate number of planes in my area that are equipped since it is home to ERAU. They have been using ADS-B for years. They report back to center and tower where they see traffic on their screens. My position is always accurate as reported by the instructors on board. So, for the poster worried about an antenna at the rear... I would not worry too much about it.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
  #18
Old 04-07-2018, 09:24 PM
Turbo69bird Turbo69bird is offline
Anyone know if this light is the same size as the standard tail light on the RV6? Looks bigger for some reason.
These guys and others are updating products so fast it makes me happy I DIDNT buy a ADSB solution yet each time something new comes out.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
  #19
Old 04-08-2018, 10:20 AM
Snowflake's Avatar
That's true with everything electronic in the aircraft... I still think the biggest reason I haven't upgraded my panel yet is that every time I start to get motivated to make some changes, the "next big thing" is just around the corner and I hold off instead... Each iteration of the technology just keeps getting better and (relatively) cheaper.
Rob Prior
  #20
Old 04-08-2018, 11:40 AM
Yeah, that's why I'm waiting till after OSH to make my final decision.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Closed Thread
