Old 12-18-2017, 03:17 AM
BigglesSA BigglesSA is offline
Originally Posted by AdamB View Post
Panel looks amazing, Mike!
Ditto from me Mike!
If I may ask, and looking at all the breakers, why you did not go for the VPX-pro?
BTW, I have almost the same panel as you planned, except for one G5, one G3X and not GTN-750. I have already placed my order with SteinAir.
Dual G3X with one set of sensors and backup batts
G5 with own backup batt and own set of sensors for backup through canbus (G5 In flash mount bracket)
GMC307
Heated pitot with AOA
GMA-245 audio panel
GTN-650 navigator
GTR-20 remote comm 1
GTX-45R Transponder (ADS-B in and out)
Virb aviation bundle
VPX-Pro
I-Pad mini in panel mounted bracket on far right hand side.
Panel is the vibre 10" side by side with the stack slightly slanted towards the PIC (left side) from Aerosport
http://www.aerosportproducts.com/Sit...ottleQuad2.jpg
Old 01-12-2018, 04:40 PM
rvdave rvdave is offline
Now flying, just about 4 hours on Hobbs!!
Dave Ford
Cadillac, Mi
Old 01-12-2018, 05:04 PM
MFMarch MFMarch is offline
Default Great looking panel!!
Excellent job!
Michael Marchand
Washougal, WA
Dues paid: 2015, 2016, 2017
N910DM Reserved
RV-10
Empennage - Completed!
Wings - Completed!
QB Fuse In work!
Old 01-12-2018, 07:51 PM
49clipper 49clipper is offline
Default 49clipper
vic,
What kind of EFIS are those, they don't look famialiar to me. Chelton? Also is that a chelton on the right side. Is it for engine only?
Jim
RV-6
Old 04-03-2018, 03:38 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Default My new upgraded panel
So after flying my RV-10 N829GW for 8 years 2 months, and 1 minor panel upgrade I decided to do a major Panel/systems update.
I removed the very first Aerosport RV-10 Standard panel and installed one of our new RV310 panels with the new quad Center Console. I went from two 8.5" AFS touch screens, to two 10" touch and one 12" touch AFS screens. I also changed over to the ADVANCED QUICK PANEL system. The new Panel has a Remote Transponder, audio panel and WXworx XM receiver. The glove box is a new product from Aerosport for the RV310. Theses are Nylon PA12 and 3D printed.
When I decided to do the retrofit I knew it was going to be a huge task to remove some systems in the airplane and dissect all the different wiring bundles. This was needed so I could determine which wires and items to keep and which to remove. Once I started disassembling, I thought, what have I done. My prior panel was working perfect and very efficient. Another factor that pushed me to do this upgrade was that I got caught up in the Navworx mess and had to replace the ADSB unit with a new legal system. I had many options but felt this was the best route to take.
After I started dissecting, I was amazed at how many wires and systems items I was able to remove because the Advanced ACM quick panel has it all incorporated. One other thing that made life easier was during my original build I had marked all wires very good and I had a good schematic to follow. Just a suggestion for all you current builders. As I started putting the new electrical system in I became more amazed at how this simplifies everything. This system is an awesome PLUG AND PLAY.
During this upgrade I decided to remove my push/pull heater cables and the Oil cooler valve and install TCW TECH linear servo kits. I also upgraded all my interior cockpit brake lines from the stock plastic ones which were getting a little brittle but still working.
With this upgrade I had to replace my Magnetometer and ADAHRS with DYNON units and 2 new 2 wire OAT sensors. All these items required new wire bundles run from panel back behind the baggage area bulkhead. I also removed my 3 original 2.25? backups and installed a Garmin G5 with battery backup and Receiving data from the GTN650. Another item removed was a Garmin 696. This was a great backup GPS unit that also handled my XM weather and music. I will miss this one. Maybe I will put it in my J3 Cub.
I started this project on 12-28-17 and finally finished 3-30-18. It was fun but a lot more work then I imagined. I had around 150HRS in this upgrade but it was well worth the effort.
Thanks to Rob Hickman, Jeffrey Hickman and everyone at AFS for putting up with all my questions. Great customer service. I would highly recommend the Advanced Quick panel systems. Also Bob Newman from TCW TECH. The Advanced quick panel documentation was excellent and very easy to understand. One great thing is everything worked great once I got all systems settings correct. The only issue I had was to swap the white signal wire on the elevator and rudder trim. That was it. I have about 4hrs now flying behind this panel and I got to say its Awesome. I am still getting use to some items but feeling very comfortable so far.
OLD
NEW
Dissecting and thinking why am I doing this
Completed and smiling again
New Glove Box
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 04-03-2018, 04:35 PM
ppilotmike's Avatar
Default As always...
..looks great!
Mike Rettig
VAF Dues Current
Old 04-03-2018, 04:51 PM
Gives me the covets. Looks great.
Dave Ford
Cadillac, Mi
Old 04-03-2018, 05:47 PM
majuro15's Avatar
majuro15 majuro15 is offline
So Geoff, is the new storage box going to be available to purchase similar to the overhead switch console? The panel looks amazing!
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 04-03-2018, 06:48 PM
Aerosport1's Avatar
Yes Tim they will be available soon.
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 04-03-2018, 07:07 PM
Jimbot Jimbot is offline
Geoff,
Congratulations on the awesome upgrade!
Now that right there is the very definition of ?panel porn?
Jim Hall
2019 VAF Annual Dues Paid
Former President, EAA Chapter 309 - EAA 309
Founder, SUPERBIRD Aircraft Cleaning Products, featuring the SUPERBIRD Aircraft Paint Restoration System
https://www.superbirdclean.com/colle...-force-members
