  #11
Old 04-02-2018, 01:50 PM
Tram Tram is offline
I've got a Champion nipple, or should. Hopefully it's in there after the last annual.
I just wanted to make sure to go from Champion to Napa (if I go that route) I won't need anything outside of what I've already got.
Old 04-02-2018, 02:08 PM
BillL BillL is offline
Originally Posted by Toobuilder View Post
3/4-16 on the engine side, but the filter side is different between the champ and tempest. In my case the Tempest nipple was required.
I mention this mainly to warn people of the possibility of a difference. Fortunately, the supply of nipples is as close as the trash can of your local FBO.
Pretty strange - I just removed a Champion filter (CH48110-1) and extracted the threaded nipple. I just this minute measured the threads and both ends are 3/4 - 16 (shoulder in between). Outer thread diameter is the same too. It must have some thread specs different on the filter head to keep it tight.
Edit: No claims for any other filter part number.
Bill
RV-7
Lord Kelvin:
Old 04-02-2018, 02:42 PM
RV6_flyer's Avatar
Originally Posted by BillL View Post
Pretty strange - I just removed a Champion filter (w/number mentioned in OP) and extracted the threaded nipple. I just this minute measured the threads and both ends are 3/4 - 16 (shoulder in between). Outer thread diameter is the same too. It must have some thread specs different on the filter head to keep it tight.
There are two different thread sizes used on our Lycoming engines oil filters. Most new ones have 3/4"-16 but some old ones like my old narrow deck engine use 13/16"-16. I only have one filter adapter sitting in the shop to measure and it is 3/4"-16. I am making an assumption that there are some 13/16"-16 filter adapters floating around and would require a different nipple or a nipple that adapts from one size to another.
Looking up the NAPA 1515 filter it lists as a 3/4"-16 thread so would not work on an adapter that used the CH48103 or CH48104 long filter that is flying on my airplane. (Change CH to AA to convert from Champion to Tempest. Tempest may have a -2 after the part number also.)
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-02-2018, 02:43 PM
Toobuilder's Avatar
OK, now it's coming back to me. I'm using a different NAPA filter and it needs the bigger (filter side) nipple that the Tempest features. Perhaps the NAPA 1515 is the same 3/4-16 that is on the Champ.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-02-2018, 05:32 PM
RV7 To Go RV7 To Go is offline
Default Filter
I use the Tempest filters and have had no issues. Purchase them in a 6 pack to decrease the cost a bit.
On my 4 I installed a Casper Labs 90 degree adapter to make it easier to change. I still had little room to the firewall. Casper told me to use HP1002 filters from K&N due to the smaller physical size (still lots of filter area inside). The guy at Casper told me they used to be a certified aviation filter before K&N bought them and are still made to the same spec with thicker wall can (for higher pressure), lockwire tabs and 1" nut. The checkvalve also works better than the Champion at keeping filtered stuff from being reintroduced into the oil. You can find them on Amazon to save even more. Worked fine for over 450 hrs and a dozen oil changes.
Al
Old 04-02-2018, 05:46 PM
catmandu's Avatar
catmandu catmandu is offline
Bob's excellent investigation on NAPA filters made me a believer. But I needed a bit of accommodation for my particular installation, so I use the 1521, which is shorter but with all the other same specs. Oil analysis as stellar as it was prior to the shift from conventional aviation filters.
I cut the nipple out of a Tempest filter with the band saw (almost, twisted the last bit to free it) and installed it on the engine with some green loktite.
I do not safety wire it. I (still) put a dab of torque seal on it, visible from the open oil door on every pre-flight. 300 hours, no movement ever noted.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 04-02-2018, 10:58 PM
jbDC9 jbDC9 is online now
Ditto! I've been using NAPA 1068 (Wix 51068) for almost 5 years now with no complaints.
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 04-03-2018, 06:41 AM
Mel's Avatar
Mel Mel is offline
Default Hint........
If you use an oil filter that has no safety wire "tab", (such as used on the Rotax) you can still safety wire it by using a large hose clamp around the filter housing and wire to the adjusting bolt.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-03-2018, 06:49 AM
Tomcat RV4 Tomcat RV4 is offline
Many of these myths date back to 20s -30s.Auto oil filters ,even in NASCAR aren't.
Wired !
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 04-03-2018, 06:53 AM
rocketbob's Avatar
l
I bought one of the HP1002 filters to try. I venture to guess it has about 1/4 the pleated media area of the 1515. Very small in comparison and unless physical room is an issue, there's no reason to use a small filter. The larger the filter, the lower the pressure drop across the filter.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
