Old 03-23-2018, 11:11 PM
jcarne's Avatar
jcarne jcarne is offline
Originally Posted by kentlik View Post
How is the riveting on the wing? That is next for me Jereme.
After I drill out all the rivets and start riveting new skins...lol
Kent riveting of the wing has been pretty easy so far. Riveting the leading edges was no problem but I did have someone to help me hold the gun steady. I wouldn't attempt anything close to the tip of the leading edge without someone holding it. Riveting ribs was easy. Riveting the leading edge to the spar was difficult to set the rib to spar rivets but the skin to spar rivets were a breeze with the squeezer. After all the bucking you have had to do for your fuselage it will be no problem at all. I also had a bit of trouble with the tank riveting but I think that was mainly because I couldn't see things since they were covered in gorilla snot! In the next week I'll be doing to top skins using the back rivet method so we will see how I do at that new task.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 03-24-2018, 09:16 AM
kentlik's Avatar
kentlik kentlik is offline
Smile
Thanks Jereme. I have found a person who I think can help me from time to time...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-24-2018, 12:31 PM
jcarne's Avatar
No problem at all, that's what we are here for.
Jereme Carne
PPL
Old 03-25-2018, 06:50 PM
jcarne's Avatar
Well after finishing the right leading edge it was time to make sure things were all in order and attach the tanks. Everything went well and they seem to fit good. There is a little bit of pillowing as most people seem to get between the tank and leading edge skin. I also primed the top skins in preparation for dimpling and riveting.
20180324_180037 by Jereme Carne, on Flickr
20180325_154547 by Jereme Carne, on Flickr
20180325_154552 by Jereme Carne, on Flickr
Jereme Carne
PPL
Old 03-30-2018, 05:12 PM
jcarne's Avatar
Well with the tanks and leading edges attached it was time for some top skins. I got them all prepped and even got the left wing riveted. My dad came over to help, we found that the back riveting method did not work for us. No matter how I held the rivet set the rivets wanted to tilt ever so slightly toward the rib web. We switched to bucking with the good ol' tungsten and it worked awesome! Really good results in my opinion. Let me know what you think.
20180327_182057 by Jereme Carne, on Flickr
20180328_211740 by Jereme Carne, on Flickr
20180330_150211 by Jereme Carne, on Flickr
Jereme Carne
PPL
Old 03-30-2018, 05:32 PM
kentlik's Avatar
WOW! I need to get on my game here! You are slamming it!
Did you do that yourself and if so how long are your arms, haha
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-30-2018, 09:36 PM
jcarne's Avatar
Haha nope, the best technique we found was my dad on bucking bar and me shooting. I give props to anyone who does this solo. Also, I will give you props if you mange to tame the long double offset rivet set. I gave up after about 10 marginal rivets.
I am trying to really slam the wings out as I already have the fuse kit, I want to fly sometime next year which means I need to have a solid summer!
Jereme Carne
PPL
Old 04-02-2018, 03:57 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Sorry to hear the backriveting didn't work for you. It worked fantastically for me, with the right tool and technique! But either way, you win!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 04-02-2018, 04:48 PM
kentlik's Avatar
Bruce, what does that rivet set look like?
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-03-2018, 12:45 AM
jcarne's Avatar
The one I have is from cleavland. Link here:
http://www.cleavelandtool.com/mobile.../#.WsMUuHNlBJc
Jereme Carne
PPL
