  #11
Old 03-26-2018, 02:45 PM
DaveO DaveO is offline
Thanks for all the responses. They give me much to think about. I was thinking about using fiberglass for the panels, but maybe aluminum would be better if I do them.
Dave
Dave
RV-7A N1243A Sold
Old 03-26-2018, 02:58 PM
Dave
Unless you're really good with 'glass, aluminum will be easier. Fiberglass, especially hand layup, will be thicker (requires spacing the backing to compensate) and inconsistent thickness, and weaker at the point loads of the screws. It's not difficult at all to make the cover plate in aluminum. Just cut a bit oversize as others have said, and work it with files/scotchbrite wheels to make it fit the hole (remember to make allowance for paint).
Charlie
Old 03-26-2018, 04:19 PM
rvbuilder2002's Avatar
As already mentioned, if you make openings in a structural skin, you should at least be using AC 43.13 as a guide for maintaining the the same strength as what the uninterrupted skin had.
This would be a lot easier to do by using the same materials vs switching to fiberglass laminate.
Scott McDaniels
Hubbard, Oregon
Old 03-26-2018, 04:33 PM
sglynn's Avatar
sglynn sglynn is offline
Originally Posted by sahrens View Post
Here is one solution. I used these on my RV-7, it was faster than fabricating my own.
http://www.mykitairplane.com/product...rvak/index.htm
Oh, I like this pre-made kit for access plates. I'm just finishing wiring on my 7A and asking myself the same question, "How will I maintain the things behind the subpanel?" From underneath is my answer, but that is beginning to seem impossible. It takes good skill to cut and make straight lines. Plus the extra material is expensive, especially if you scrap some. This kit really simplifies make the access. You only have to cut the access hole.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 03-26-2018, 06:14 PM
jliltd jliltd is offline
Exactly. Follow AC 43.13 as Scott says. The strength can be maintained but only the weight will go up due to reinforcing and fasteners.
But I have to admit. Once you have one of those 10" + glass displays, when removed it yields a huge access panel and makes life great when working on the backside of the panel. That alone is a big plus for those big square TV looking thingys.
Jim
RV-8
(a few more airplanes too)
Old 03-26-2018, 06:15 PM
TCONROY's Avatar
TCONROY TCONROY is offline
I put 2 access panels in my -7 Tip-Up during construction and after 3 years of flying would absolutely do it again. I have the VP-X, remote transponder, and other avionics equipment just aft of the firewall and it is a bit difficult to get to when the interior is in. he access panels make it SO easy. I made doublers for the forward skin with two rows of rivets around the perimeter and brought them over to Van's. One of the engineers unofficially blessed it so I moved ahead with it.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 03-26-2018, 07:42 PM
JDA_BTR JDA_BTR is online now
What do you do to prevent water intrusion?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
Old 03-26-2018, 08:33 PM
TCONROY's Avatar
I smeared a very thin coat of the FlameMaster (makers of ProSeal) access panel sealant before securing the covers. I can't remember the model number of the sealant off the top of my head. Water has never been an issue.
________
Airbus Pilot
N781TD
RV-7
Construction Log
Old 03-26-2018, 09:44 PM
joe_rainbolt's Avatar
joe_rainbolt joe_rainbolt is offline
Default Access panels double as GPS antenna mounts
In my access panels I used fiber glass instead of aluminum. The access panels incorporate molded in mounts for GPS antennas. There are three total in my system and all are working great in this location with an excellent view of the sky. I find this location to be superior to the engine compartment or on top of the cowling.
I did not do an FEA on the air frame after I cut out the panels (I seriously doubt Vans did one either for the RV7) I kept the opening size as small as was reasonable that would still accommodate the antennas and I used the same spacing for the screws as was used for the rivets bonding the skin to the air frame. The screws were #6.
I have my VPX Sport mounted directly behind the panels and I've had to take that out twice in two years. I've also added another GPS antenna in that time. I think I've opened the panels 4 or 5 times in the two years and I am very happy that I took the time out to build them.
I neglected to take any pictures with the GPS antennas installed, but here is a photo that shows the sizing.
Joe Rainbolt
RV-7A slow build complete 4 July 2016
Visited all 48 contiguous states July 15-29 2017.
Blog: www.roughandreadyaerospace.blogspot.com
Old 03-26-2018, 11:07 PM
Av8torTom's Avatar
Default Not so sure
I would argue that cut-outs in the skin, like the OP made, with a frame riveted around the opening and the 'doors' screwed into the frame nutplates would be stronger than the original un-opened skin. This is similar to putting a sun roof into a car. Despite removing all that metal, the sun roof frame actually stiffens and strengthens the roof.
Nice job Al.
N677AT reserved
Superior XP O-320, 160HP
