Old 03-25-2018, 09:03 PM
StressedOut StressedOut is offline
Default ProSeal Clean Up
I just had my first experience with ProSeal where I used it to bond the rudder trailing edge together. I was pretty careful with it and didn't get any on my clothes, but I did get a small amount on my hands and forearms.
This stuff doesn't come off easily I found. What do you guys use to get if off skin?
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 03-25-2018, 09:08 PM
terrye terrye is offline
Default Proseal Clean Up
The best idea is to use latex examination gloves while working with Proseal. The next best idea is to use a barrier cream. If it were on my hands I think I'd just let it wear off (like I did as a kid with Ambroid glue from modelling) as any kind of solvent that would remove the Proseal would likely be harmful to your skin.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 03-25-2018, 09:13 PM
Plummit's Avatar
Plummit Plummit is offline
I wonder if WD-40 would cut it? It's been used as a cleaner for several things.
-Marc
RV-10
N814RV
2020 Donation Made
Old 03-25-2018, 09:15 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Actually, ProSeal comes off readily with just soap and water. Takes about three weeks.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 03-25-2018, 09:32 PM
Carl Froehlich's Avatar
Lacquer thinner. It will also take off several layers of skin - so fair warning.
Carl
Old 03-25-2018, 09:56 PM
Jake14 Jake14 is offline
I've always used acetone, works well and doesn't seem to take any skin off
RV-14A flying 410 hrs
Old 03-25-2018, 09:57 PM
I use acetone too (used it today, in fact), but in very modest quantities.
The best solution is to wear an old (disposable) long sleeve shirt and nitrile or latex gloves.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-26-2018, 06:52 PM
I asked our one of our AOG team about this today and he uses Wypall cleaning wipes. He gave me one and combined with a bit of elbow grease it seemed to do the job. As a bonus is smells like citrus!
https://www.grainger.com/product/4YC...180327005027:s
Art Jackson
Scrapped: Rudder
Old 03-26-2018, 07:21 PM
Mudfly Mudfly is offline
Maybe I've been lucky, or have bad proseal, but I've had good luck applying body lotion to proseal covered skin and let it soak for a bit. Then just soap, rag and water seem to get the majority cleaned off.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2020 VAF Donation
Old 03-26-2018, 08:49 PM
BobRv4 BobRv4 is offline
Default Hand cleaner
The best non toxic stuff is "GOJO" Natural Orange PUMICE hand cleaner.
The stuff works great no sticky feeling on your hands when you are done.
Or find something with pumice in it, like old Lava hand soap if they still make it.
