Old 03-20-2018, 02:04 PM
Flandy10 Flandy10 is offline
Default Rv-10 TDI 1st Condition Complete
Well, it took about 2.5 months, but its back in the air- sort of.
The condition inspection went very well. RV guru Vic Syracuse gave the airframe a thorough inspection. He left the engine to me.
Punch list items--
1. Aileron SB inspection- completed- no cracks.
2. One brake master cylinder fitting weeping- resealed all 8.
3. Two small cracks in the inlet ramp baffles- stop drilled.
Modification list--
1. Upgraded rudder stop installed-recommended by Vic.
2. Reduced my aux battery system by half- saved about 8 lbs.
3. Installed an access door in aft bulkhead- Now just 10 screws instead of 35 to check the battery and aft equipment bay.
4. Enlarged oil cooler inlet and ducting
5. CMI installed a production version oil pump -- This was a huge disassembly job that is half of the reason for the lengthy condition. Checking to see if I can post photos.- standby.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
2020 VAF Donation complete
Old 03-20-2018, 02:07 PM
Now for the "sort of" answer....
During a post condition test flight, I found one of the eight induction clamps migrating. They're not supposed to move and didn't during the first 100 hours.
When your running 90" MAP at takeoff, you don't want ANY movement in these clamps.
Still troubleshooting the issue, but I did find that the migrating clamp's spring has gotten shorter compared to a new one.
Checking with manufacturer...
to be con't.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
Old 03-20-2018, 09:26 PM
unitink72 unitink72 is offline
Default Rudder stop
Never heard of an upgraded rudder stop. Got a link or pics?
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2019 Dues Paid
Old 03-21-2018, 05:08 AM
Super Moderator
One example is sold by Flyboy accessories, called the internal rudder stop. Or you can make your own from aluminum. The kit rudder stops have been known to break the rivets in high wind conditions when parked without securing the rudder. Mine included. It can happen while at a fuel stop when someone inadvertently pulls away with a lot of power and the prop blast is facing your RV10. When that happens the rudder contacts the elevator and usually leaves a dent or a hole in the rudder.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 03-21-2018, 05:51 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Thanks for posting your findings during the inspection Scott.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 03-21-2018, 06:07 AM
DanH's Avatar
DanH DanH is offline
And you believe the internal rudder stop is structurally better?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-21-2018, 06:19 AM
Jesse's Avatar
Jesse Jesse is offline
The easiest way to upgrade the rudder stop is to replace the #4 rivets with #6 screws and nuts.
Jesse Saint
Old 03-21-2018, 06:51 AM
SabreFlyr SabreFlyr is offline
Offhand, Dan, I'd guess "yes." The internal stop would be nylon against the heavier gauge aluminum rudder spar whereas the standard stop is heavier gauge aluminum against the lighter gauge aluminum skin. Granted, I believe the contact is where the skin is backed by a rib but the internal stop is contacting heavier gauge that is also backed by heavier gauge.
Ray Dosh
LJ45 driver
RV-14 QB #140212
Tail feathers finished
Tail cone in progress
2020 DUES PAID
Marion, IN MZZ
Old 03-21-2018, 07:32 AM
Super Moderator
Well, I haven't done any FEMA analysis on it, but after mine broke from a gust of wind and put a hole in the rudder, I made a solid piece similar to the nylon one provided by Flyboys. It hasn't broken since. Nor do I think it is now capable of breaking.
I see Jesse mentioned replacing the rivets with screws. I thought about that but didn't want to be a test bed again. I also think there is more surface area contacting the rudder now as well.
Vic
Vic Syracuse
Old 03-21-2018, 10:53 AM
ppilotmike's Avatar
Default Extra Rear Bulkhead Material
Scott,
Did you have to order another complete rear bulkhead panel in order to make the doubler behind your door? If not, how did you get the material needed to do that door? I'm interested in following in your footsteps, but want to be sure not to reduce the structural capacity of the rear bulkhead. Thanks.
Mike Rettig
VAF Dues Current
