Originally Posted by Blain
Contacted Flightcom and was told to send them back. I?m cool with that but I?m still curious about none of the headset manufactures using usb for power.
Not sure why they would... In certified aircraft, adding a power jack of any kind isn't the most trivial exercise. In an amateur-built, the market is much smaller, and the variety in what people want is much greater.
12V is readily available in an aircraft. That's what LEMO jacks are for. Wire one in alongside your standard jacks, so you can still use a standard headset, if you're concerned about that. Or replace the standard jacks and use just the LEMO, and carry an adapter GA-to-LEMO for the times you want a standard headset.
