  #21
Old 03-20-2018, 04:51 AM
Tom Martin Tom Martin is offline
The easiest thing would be to go with two mags. Pretty close to 100% of the cert. aircraft are using them. Next, after 200 to 300 hours, by which time you will really know the airplane, swap out one mag for one of the many alternatives.
Fly for another 150 hours or so and either rebuild the mag if you are happy with how things work, or add the second electronic ignition.
If you do it this way you will know if there are improvements that are important to you and your airplane.
I fly with one electronic ignition and one mag. I like it but that does not mean that you will.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 03-20-2018, 06:27 AM
pa38112 pa38112 is offline
Two Pmags for this reason: The Pmags change the timing based on RPM/MP. If you did one standard mag it would always be firing off time from the Pmag, either doing nothing or negating the timing change of the Pmag. The purpose of two plugs per cylinder is to have a larger, even flame front across the large bore area. You loose that if you are firing from only one side.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 03-20-2018, 08:49 AM
Av8torTom's Avatar
Default Thanks
Thanks everyone. The decision is to go with two P-mags.
I?ll post a pic shortly
N677AT reserved
Superior XP O-320, 160HP
Old 03-20-2018, 03:29 PM
Av8torTom's Avatar
Default Dual P-Mags
First one installed
Both in place
Me and my build instructor Darrell
Thanks everyone for all the helpful advice. This forum rocks!
N677AT reserved
Old 03-20-2018, 04:36 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
And I though the two plugs per cylinder in traditional aircraft engines was for reliability since there are two magnetos usually involved.
Could two magnetos even fire a single plug easily?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
