03-19-2018, 12:02 PM
Cooling fans
Exciting day - powered up for the first time !
The two fans on the base of the sub panel - anyone know if they are designed to run all the time, or only when the Skyview fans run ?
Everything else looks OK, but those fans aren't running.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
03-19-2018, 12:15 PM
If I remember I think they are on the Fuel Pump Bus.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
03-19-2018, 12:36 PM
They should turn on with the Master Switch, but if you have the 5A fuel pump fuse removed, they won't run (same circuit).
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
175 hours and counting.....
03-19-2018, 04:46 PM
Hmmm - just tried it and yep, that's it !
Bizarre. Should really have a switch on the pump
Thinking cap on for an attractive solution.
Thanks for the quick replies.
Donated in 2020
03-19-2018, 07:23 PM
Check Modifications thread for various pump switch solutions.
rgmwa
RV-12LR 912ULS
120346
03-20-2018, 05:18 AM
Thanks, will look. Airplane 1 is nearly done, Airplane 2 is waiting avionics so is easier to modify..
Donated in 2020
03-20-2018, 06:19 AM
Where?
I've been thinking I need fans for my avionics. Just curious, can you guys expound on where these fans are and their configuration please? Imitation you know. Thanks!
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
03-20-2018, 07:32 AM
There is a very specific reason the fuel pump is not on a switch.
I strongly suggest you fully understand that before adding one.
Scott McDaniels
Hubbard, Oregon
03-20-2018, 10:15 AM
^^^^ Hint... it has to do with safety.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
03-20-2018, 11:00 AM
Mani, the avionics bay on the RV-12 is completely enclosed. The bottom is not open like many other aircraft. The two fans are mounted on the bottom of the avionics bay. One fan blows in and the other blows out.
Joe Gores
RV-12 Flying
