Old 03-19-2018, 07:46 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Default Which screen first?
Does it matter which screen receives the update first? PFD-MFD (Left to right) or MFD-PFD (right to left)??
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 03-19-2018, 07:56 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Anthony,
No, it doesn't matter, but personally I like to insert the software update card in the MFD and power up the MFD and update that display first, they power-up the PFD and update it.
When the PFD resets after loading the software to internal memory, I hold down the menu key to bring it up in configuration mode so I can watch all of the various devices being updated on the system information page. Only when all of the software updating by the PFD is complete do I restart the system in normal mode.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-19-2018, 08:54 AM
Brantel's Avatar
Brantel Brantel is online now
Originally Posted by g3xpert View Post
Hello Anthony,
Steve
I second Steve's method! I like to see the LRU's update so I know when they are finished. Seems to help eliminate surprises later...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-19-2018, 09:00 AM
bkthomps bkthomps is offline
i have only had luck by updating one at a time, and leaving the adjacent screen powered off completely
otherwise I get high network error rates on at least one module when updating, I have no idea why this is, and my can bus passes all the tests
Old 03-19-2018, 10:33 AM
Dorfie Dorfie is offline
Hello Anthony,
Steve
Steve,
This is interesting.
I've always used 2 SD cards and updated the 2 screens at the same time.
Any issue doing it this way?
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 03-19-2018, 01:25 PM
g3xpert's Avatar
Post
Originally Posted by Dorfie View Post
Steve,
Thanks.
Johan
Hello Johan,
No problem using 2 software update cards if that is what you want to do, but since it only takes about 15 secs to do a software update, I sure wouldn't take the time to create/maintain two software update cards.
It is more common for people to use two database update cards to cut down the time for that loading activity, and perhaps that is what you meant.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-21-2018, 08:20 PM
jliltd jliltd is offline
I just installed v 5.90 in an aircraft that previously had autopilot trouble with v 5.70. Everything seems okay. However, it took well over an hour just for the G5 update. The servo updates were about 15 minutes. The automatic update went in the sequence of GDU 465 (less than 20 seconds) then upon reboot the system updated the autopilot servos. Then came the G5 update. An hour later the servo update executed again. Glad I had a maintainer on the airplane. So be wary of the update if depending on ship's battery alone.
Jim
RV-8
(a few more airplanes too)
Old 03-21-2018, 09:55 PM
Jim
Interesting. I just upgraded from 5.6 to 5.9 and the whole process took about 5 minutes with the G5 and servos taking the longest. Could be 5.7 had something to do with your long update.
Anthony
Old 03-22-2018, 08:05 AM
g3xpert's Avatar
Post
Hello Jim and Anthony,
Of course the software update I was referring to taking 15 seconds is the transfer of the new G3X Touch software for all LRUs into each GDU 4XX display from the SD card.
The updating of each device on the can bus (e.g. servos and G5) which has new software for a particular update is an additional update time, but not generally long.
If you are in configuration mode on the PFD and seeing a device taking a long time to update (e.g. G5), remove power from everything in the system but PFD1 and the device you are trying to load. This will remove all other communication from the CAN bus and streamline the software load to the device which is not completing the software update.
It is ok to power up a few devices with PFD1 (e.g. all servos) when they are on the same power circuit, but the main thing is to remove as much as possible to reduce non-essential communications on the CAN bus during a software update. Powering off some devices on the CAN bus is generally not necessary, but can be a good way to resolve software update issues when observed.
Please contact us directly by phone or email if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-22-2018, 08:59 AM
Robert Anglin Robert Anglin is offline
Default Us too.
We like the way Steve has mentioned. We take everything off line, then boot up the GDU. Load the new software and then bring the other items in the Garmin system on line. It take a minuet or less each time we up-date. We were running 5.7 with no problems and just switched to 5.9 a couple of flights ago. It so far checks out just fine.
I asked Garmin and they tell me that they are planning to bring the gear to up-date GTXer's to Sun and Fun, so we will get that done as well if needed.
Hope this helps. Yours, R.E.A. III # 80888
