I have quite a few cutouts available. Round. Round with provisions for kohlsman knobs or VSI. 3 ATI. And even versions for when using wedge lights (nulites etc...). I even have switch and circuit breaker cutouts with the index tooth. Same for various ELT heads, USB charging ports and ACS ignition/start switch. I use laser cutting so my details don't worry about minimum router diameters but can be radiused through a corner trim command in CAD.
Which CAD program or file format do you use?
Jim
RV-8
(a few more airplanes too)
