02-20-2018, 08:21 AM
Senior Curmudgeon
Originally Posted by BobTurner
I had a nearby construction equipment rental place that rented me a tilt-bed truck.
Yep, me too.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-20-2018, 10:57 AM
I used a flatbed tow truck for my 7. They were pretty excited to help, charged me $100.
02-20-2018, 10:04 PM
delivered
5 miles, 30 minutes, no hassle, $125. Delivered into my hangar.
02-21-2018, 06:04 AM
Flatbed is the way to go, but leave the horiz. stab OFF.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
02-21-2018, 05:54 PM
Thank you all for the many suggestions. Now it looks like I have a few different options.
03-04-2018, 03:36 PM
If I may be so bold as to hijack this thread, I think all the photos I've seen of the move to the airport have been of aircraft already on gear. Anyone ever move the plane from garage to hangar before putting it on gear?
Jeff Rich
RV-10 KJVY
N313KC registered
Awaiting Airworthiness Inspection--soon! (fingers crossed)
03-04-2018, 03:57 PM
I moved mine several times with the gear off and on. I believe it is quite a bit easier off the gear than on. I built a 4'x5' platform for the fuselage to sit on to move around in my garage. I used a piece of plywood to roll the fuselage onto the trailer and then off. It worked fine. It is much easier to work on the fuselage off the gear and if I were to build again, the gear may be one of the last things to install!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
03-04-2018, 07:11 PM
I just purchased a RV10 project on the gear. Hired an aircraft recovery company to move it. They normally moved crashed planes. They lifted it onto a trailer with a set of Gin poles and a winch. They had a bar that was wider than the fuse and they dropped straps down each side to the spar. Took a small amount of balancing (pitch). It worked great. Everything else was inside a trailer. You might see if there is a recovery co. in your area.
03-04-2018, 07:24 PM
Thanks.
(Here are my additional characters to make it a suitable length)
Jeff Rich
RV-10 KJVY
N313KC registered
