  #31
Old 03-02-2018, 07:06 PM
laz laz is offline
A couple of years ago Christer at Stein air won a Lindy with his RV8. He had the cowl off to show his beautiful wire work forward of the cowl. He use a Lacing tape that was white with black threads running thru it on much of the wiring. It is Nomex lacing tape. Not easy to find but it is available and I was lucky and found a roll on Ebay. It is rated for a much higher temp than zip ties. It is used in many turbo prop planes forward of the fire wall.
