Old 02-22-2018, 01:26 PM
Kevin Handley Kevin Handley is offline
Default Rv12 Spar Pin Light
Hello all
Just bought a rv 12 and noticed that the spar pin light was lit and the engine would not start the owner said that he was told that it was probably a faulty sensor and the pins are in place ok just touch the top of the pins and it should deactivate the light which it did.
Any help to sort this out would be appreciated
ThNks in advance
Old 02-22-2018, 02:00 PM
DaleB's Avatar
DaleB DaleB is offline
If it's an older one (not sure about the new ones), there is a magnet glued into the top of each latch pin. One of mine came loose, and would occasionally cause that symptom. All I have to do is push down on the tip of the latch pin to re-seat the magnet, and all's well. Next time I'm in there (and remember it) I need to dab a little epoxy or put a drop of superglue on it.
The alignment of the reed switch can also be a little touchy. You can adjust the position of the switch for more reliable operation. One of mine needed about 1/8" of adjustment right after I bought it.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-22-2018, 03:58 PM
AZLeeJay AZLeeJay is offline
You can always push the spar pin light in and the engine will start with it depressed and continue to run with it un-depressed.
Old 02-23-2018, 06:55 AM
Mich48041 Mich48041 is offline
Move the magnetic reed switch closer to the magnet. Or better yet, mount the reed switch parallel to the magnet.
Joe Gores
RV-12 Flying
Old 02-23-2018, 08:11 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I fought mine longer than I should have, finally achieved success by bending the legs on the clamps to allow a better relationship between the switch and the magnets.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 02-23-2018, 12:06 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Spar pin switch upgrade is available
For the OP and other's with the old style switches. The magnetic spar pin switches are a bit hard to adjust, and can be pesky. Van's changed the design to mechanical push switches in 2015 and there is a retrofit kit available
http://www.vansaircraft.com/pdf/Noti...2015-09-15.pdf
I have upgraded using the kit and the mechanical switches work well and are much easier to adjust.
Tony
E-LSA RV-12 ULS
Old 02-24-2018, 12:03 AM
Handclutch Handclutch is offline
I had the same problem and fixed it by taking about I/8? off the tubes to better expose the magnets - works perfectly now.
Jack
Old 02-24-2018, 02:53 AM
Default Spar pins
Thanks All for your replies
Old 02-24-2018, 10:23 PM
I helped a guy fix his. It was actually a bad reed switch, so I recommend putting a strong magnet up against the switch first to be sure it?s not magnet position that is causing the issue.
